Member # 2099
4.77s + 4.88s
Is the difference between a 4.77 gear set and a 4.88 gear set to much for you to be able to run together (4.77 rear axle, 4.88 front axle)? I'm guessing it probably is, but I just want to check. Trail only rig, mostly rock
BTW, I understand there is a chance of getting away with it if I were to play with the tire pressures some, but that seems like a real PITA Last edited by LostIt; 11-12-2005 at 03:28 AM. |
Member # 49302
I just regeared to a similar set-up. 4.77 fr, 4.88 R. So far so good. I've run them on one trail weekend, and they did well. I played with the tire pressure to acheive a 0.35" difference in tire radius. I ran in 4low for miles and never noticed any pulling or binding. I did get some excessive heat from the front diff, but I think that is the product of bad bearings. It does take some extra attention, but wheeling on the east coast, we don't get many high traction situations. If it was terrain like Moab, I'd be alittle more wary.
#3 (permalink) | |
Member # 30359
The standard is normally a 1% difference is ok. The difference in those ratios is about 2.3%. It will probably be ok, but you're pushing the limit.
BDR 67 FJ40 "Last Minute" - build thread 97 XJ Quote:
Member # 2099
yeah, I did the math a few days ago and thought it would be to much. Most of the places around here I think I could get away with, but I'm pretty sure the granite in mason would not be kind.
Member # 62
most people don't pay an anal retentive amount of attention to air pressure in there tires and I'm sure often get a difference front to rear similier to what you have going on, hell if you run tires from interco and don't pay attention you could get an even bigger difference. Also several toyota guys on this website (including gearman who runs a very reputable gear shop) run 5.38 front 5.29 rear succesfully.
Worst case scenerio go out and air your tires down to a pressure you would likely run then play with it a little to get a 2-2.5% difference in the loaded radius front to rear. Remember this number and it won't be a pain in the ass.
Jeff Neves |
On Vacation>>>>>>>>>
Member # 55521
my friend has a k5 and he has 4.56 front and 4.10s rear, iknow thats a huge differance and if he drives it on anything hard itll blow, but would it brake anything in mud? i know thats a stupid question
but what do you guys think?
Trail Tampoon
Member # 27333
i ran 410's in the front and 3.73's in the back of a tj on 33's and it is was fine for OFFROAD ONLY. as long as there is some alowed tire slippage you should be fine. engaging and disengaging was a little hairy but that is to be expected.
83CJ7-350 on pane-465-205-chromo 60&70-h1s-42" SX2s-linked F&R - ORIs 90YJ - stock-ish 1970 Commando under the knife: /forum/jeep-hardcore-tech/900628-urban-commando-project.html |
what is the point of running 2 different gear ratios? i dont see the point in it other then blowing the diff. apart. someone please explain why someone would want to run this setup.
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
#9 (permalink) | |
Trail Tampoon
Member # 27333
means to an end my friend. i did the front with 410s and ran it while i was waiting to get my 8.8 installed that was already geared. i olny ran that way for a couple months and only two trips in 4wd
83CJ7-350 on pane-465-205-chromo 60&70-h1s-42" SX2s-linked F&R - ORIs 90YJ - stock-ish 1970 Commando under the knife: http://www.pirate4x4.com/forum/showthread.php?t=900628 |
#10 (permalink) | |
Member # 18006
President Gettin' Off 4X4 Club '89 XCab - Dual Marlin w/4.70 in rear case, D60 Hybrid SAS, locked, FJ80 HP front, ....... '97 TJ - Atlas 3.8 TC, ARB's F&R, ...... |
