Member # 207
It lets the tire flex and grab more
JeeP YJ 38.5 sx's on hummer wheels FULL WIDTH rc44 / 60 spooled /soa 435/300/4:1 And total disreguard for body damage I live for the High Angle giveaway's |
#7 (permalink) | |
this is kinda a stupid question, your going to buy tires that are $200-$500 each and cut them cuz someone says its a good idea? my advise would be dont listen to anyone about cutting them, run them stock and see if its good enough, then cut if you really want to
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
Member # 603
Boggers were created specifically to BE cut. That's why the 44" was the first size released & why Interco gave an advance release pair of them to Ron Pense (reigning NMRO mud racing champ) in 1992. Many people think that cutting simply involves removing the smaller lugs, but it entails SO much more. The premier cutter is Jimmy Dean out of Chicago & the price of a Dean-cut tire is more than double the price of an uncut tire. A Dean-cut 39.5 Bogger weighs 60lbs - an uncut 39.5 is 110lbs. A Dean-cut 44 is 1.5" deep. And they look like this:
Naturally, they work better in mud than an uncut DOT tire, which is why cutting of tires is illegal in all but the uppermost classes at any mud race. TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
Member # 63741
well the stuff im runnin through is some pretty nasty stuff and i got quite a load to pull lol but i do agree with you net i plan on runnin em like they are and then ill probably cut em
Member # 38560
Tex is right, they are designed to be cut-when using offroad. I would not recomend driving cut boggers on the street. You will really notice the increased traction in the mud but it will also cost you some horsepower to turn them compared to the uncuts. I cut all 4 44's on my mud truck and the increased traction is awesome, I also left my front axle open to try to save some parts! I didn't go as wild as the racers because I wanted a little more support for the lugs in case I hit a rock or stump.
ROAD RAGE: S-10 on Rockwells, Kings and Profab, 725 HP BBC, 57" Rice & Canes '07 Chevy 2500 HD Duramax 8" Fabtech, 37" Procomp Xtremes, 20" Ultras, Edge w/ attitude, Magnaflow 4" exhaust [COLOR="Yellow"][U][url]www.ouversonengineering.com[/url][/U][/COLOR] |
#12 (permalink) |
Member # 64579
it also depneds on how you cut them. if you cut the small lugs right out they are gonna wear like hell on the street. on thing that is said to make them a perform a little bit better without killing you street wear is to sipe them. nothing major just 2 or 3 exacto knife cuts in each lug.
this will help them grab and help the lugs flex more on trails but on the street the sipe will also help cool the tire which helps the life of them... just my 2 cents as they said dont cut em cause somebody said to it all depends on what your using them for.
[SIZE="5"][CENTER][FONT="Arial Black"]1981 Chevy,1 ton,44's,big block[/FONT][/CENTER][/SIZE] |
#13 (permalink) |
I think someone earlier in the thread was refering more to GROOVING them than CUTTING them. There is a very distinct difference. Grooving entails putting small, well, grooves in the lugs. It is true that this increases horizontal traction of the tire and increases the sidehill ability of this tire. Ungrooved the large lugs act like skis and slide downhill.
#14 (permalink) |
speaking of how they wear down, whats the life span on boggers? im wondering if i should mount my boggers on different rims and just swap them when i take it off road, i dont wanna be wearing out my $1,500 set of tires just for road use.
