heater ?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2006, 02:20 PM   #1 (permalink)
Member # 14022
heater ??
The heater in the chevy 4X4, 1981 has suddenly decided to stop blowing hot air. It will blow semi warm but will not ever get hot. First thought was maybe the thermostat, changed it out but that did not help. The water seems to be circulating ok through the radiator. I'm guessing the heater core is clogged up. WIth it hot and running the hose that comes from the connection on the top of the intake manifold is hot but the one that comes off of the water pump is cool/cold. I'm assuming that the water runs through the block and into the heater core through the hose coming off the intake manifold and then returns into the water pump, correct?
Any other thoughts or suggestions on possible soulutions. THis ()*(* always has to happen when it's 26 degrees and snowing
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
Wow! What a ride!'"
Mike Catts is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 06:27 AM   #2 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Actually, the purpose of the thermostat is to restrict flow until it warms up. Just had to replace the t-stat on my Saab. Old one was stuck open and things never warmed up. New one actually was faulty - ended up opening too soon and things never warmed up. Second new one worked like a charm.
Just something to check.
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 08:06 AM   #3 (permalink)
Member # 52028
Your assumption about the water flow is correct. If your hoses are warm then the hot water is getting to that point. I'd pull the hose that isn't warming up and see what kind of condition it's in. It could be old and collapsing, or you could have blockage at either end. Check the pipes out and see which end it's bad on and go from there. The water pumps like to corrode, so your heating issue may be a sign of an impending water pump failure as well.
dubbyx is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 08:36 AM   #4 (permalink)
Member # 54549
easy enough to swap the tstat
My wife still doesn't know about Pirate4x4.SHHHHH!
Sky high!
s1037s is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 04:47 PM   #5 (permalink)
Member # 14022
I have put in a new thermostat and that did not solve the problem. I don't think that it is the water pump as I can leave the radiator open and watch for the water to start circulating after the vehicle warms up and the fact that the pump is only a few months old (replaced when I put a new motor in) I guess I'll pull the cool heater hose and see what happens then. I also picked up 2 of the inline heater hose cleanouts that you can hook a hose to. Will give a try to forcing water through the heater coil and see what happens then.
ANy other thoughts?
Thanks
Wow! What a ride!'"
Old 01-18-2006, 08:00 AM   #6 (permalink)
Member # 54549
sorry. missed that in your first post.how hard to put a new core in?
Sky high!
Old 01-18-2006, 05:36 PM   #7 (permalink)
Member # 14022
s1037s, not sure how hard it is to replace. As soon as I have some breathing room to spend a little time I'll let ya know. Judging by the book it does not look like just a whole lot of fun.
Wow! What a ride!'"
Old 01-19-2006, 06:18 AM   #8 (permalink)
Member # 54549
i talked to two buddies last night and one said easy one said hard
Sky high!
Old 01-19-2006, 08:45 AM   #9 (permalink)
Member # 37021
Send a message via AIM to Chevyboy51
your cable broke that controls the flow valve. pull the glove box out and you will see the valve on top of the heater box. heater cores don't plugup quick its a long slow process.
77 shortbed 406/th350/203
d60 /14b/limitedslip/detroit/39.5 tsl
soon to have 52" fronts th400/205
Chevyboy51 is offline   Reply With Quote Quick reply to this message
