fiberglass bodies - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2006, 07:53 AM   #1 (permalink)
JJS
Member # 28835
fiberglass bodies
anyone have any first hand wheeling experience with fiberglass? my cruiser has a fiberglass tub on it, as the original body rotted away long ago. it's of pretty strong construction, with very solid floor boards, fenders wells, and fire wall. i do want to wheel it when it's finished, and i've taken most of the precautions to make sure the fiberglass won't crack (plating bolts, etc.).
so the question is, for anyone running a fiberglass tub, how has it held up long term to abuse?
2012 JK. Stock as hell for now.
JJS is offline   Reply With Quote
Old 02-05-2006, 11:30 PM   #2 (permalink)
Member # 14644
i don't own anything fiberglass....but will say this, as soon as it touches rocks it's toast. It's a composite, and "most" composites have horrible impact strength.
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 02-06-2006, 07:32 AM   #3 (permalink)
Member # 55458
I have wheeled my CJ7 with 'glass tub often. It does fine, but I plan on putting rocker guards on it. Right now, it has sidepipes w' headers, so they are taking the shots. Don't want to find out what happens if a rock contacts the tub, it will be a hole for sure.
Icemanii is offline   Reply With Quote
Old 02-06-2006, 07:42 AM   #4 (permalink)
Rattlecan's Avatar
Member # 50639
Fiberglass is unforgiving. If you plan on mild wheeling with minimal contact with trees, rocks, etc it will do fine. Might want to invest in rocker protection, and maybe a partial exo. Make sure the rocker and exo are tied to the frame.
Rattlecan is offline   Reply With Quote
Old 02-06-2006, 12:19 PM   #5 (permalink)
Member # 12414
I like my glass body been on for about 16 years now armor it and you'll be fine.It is easier to fix then metal, but you can trash anything.
Team Devil Frogg
Kettering, Ohio
GPERX4 is offline   Reply With Quote
Old 02-06-2006, 12:44 PM   #6 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
If it is done right, fiberglass will last a long time and handle alot of abuse. Properly laid up 'glass will actually flex a bit and absorb impacts. Just don't expect to be able to drag it over rocks.
Fourwheeler mag's Ned Bacon's Killer Bee flattie has had a 'glass tub for 20 years and it has been bounced off of rocks for many, many years with amazing little damage.
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market!
Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers
http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363
Tech Tim is offline   Reply With Quote
Old 02-06-2006, 03:35 PM   #7 (permalink)
JJS
Member # 28835
i have rocker guards and sliders on it. i think it's gonna do okay. i just wanted some opinions. the truck's not done yet, so it hasn't been wheeled.
