Hi Lift Handle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-08-2006, 12:48 PM   #1 (permalink)
ACHASE6002's Avatar
Member # 54836
Hi Lift Handle
Who Make A Hi Lift Handle Replacement?
ACHASE6002 is offline   Reply With Quote
Old 02-08-2006, 01:30 PM   #2 (permalink)
Christian hater arg!
CrustyJeep's Avatar
Member # 29527
How about a piece of pipe/tube cut to length?
Originally Posted by JK3078 View Post
To fucking ignorant
CrustyJeep is offline   Reply With Quote
Old 02-08-2006, 01:35 PM   #3 (permalink)
CINCH's Avatar
Member # 8171
x2, it would be much cheaper
CINCH is offline   Reply With Quote
Old 02-08-2006, 03:34 PM   #4 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
i belive that Hi-lift also sells a replacment
Shane
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 02-08-2006, 07:21 PM   #5 (permalink)
88wildrunner's Avatar
Member # 42067
Send a message via AIM to 88wildrunner
check out home-depot
88wildrunner is offline   Reply With Quote
Old 02-08-2006, 07:52 PM   #6 (permalink)
Member # 52028
if you go pipe, you can cut it to any length you want it... made a huge difference when I made my replacement on lifting my 'burb. makes for a longer cheater bar too...
dubbyx is offline   Reply With Quote
Old 02-09-2006, 10:13 AM   #7 (permalink)
ACHASE6002's Avatar
Member # 54836
For Some Reason I Thought There Were Threads In It Somewhere, If Theres Not I Ll Use A Piece Of Tube
Old 02-09-2006, 10:20 AM   #8 (permalink)
CINCH's Avatar
Member # 8171
No threads, just slides in
Old 02-10-2006, 07:08 AM   #9 (permalink)
Dparker11818's Avatar
Member # 27201
I use a broken axle shaft for a handle in mine. Works great. I lost it some how and I had the shaft so I use the hell out of it.
Dparker11818 is offline   Reply With Quote
Old 02-10-2006, 07:54 AM   #10 (permalink)
Member # 52028
nope, no threads, but putting a catch pin to hold it isn't a bad idea... I've picked mine up and dropped the handle on my feet more times than I can count. if you get pipe from HD or Lowes or wherever, a lot of times they have that little plastic protector over the pre-threaded area. leave it on the loose end of the handle for bling and +5 hp.
