Little black box? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-26-2006, 10:49 AM   #1 (permalink)
Member # 44140
Little black box?
On a 92 V6 3.0. Its next to the airbox with two hoses to the top part and one to the lower part, and the lower part goes to the intake tube after the Mass air flow sensor. Do i need these or can i just plug the openings and run it?
CNC people look here
[url]www.PiersonIndustries.com[/url]
93TOYforME is offline   Reply With Quote
Old 02-26-2006, 10:51 AM   #2 (permalink)
Angry Gecko
flecker's Avatar
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
Oh, I am pretty sure that is a bomb man...
I R A REVOLUTION LEADER!
flecker is offline   Reply With Quote
Old 02-26-2006, 10:56 AM   #3 (permalink)
Member # 44140
I found a post on it earlier but cant search anymore. just trying to figure out what it is.
Old 02-26-2006, 10:57 AM   #4 (permalink)
Angry Gecko
flecker's Avatar
Member # 23744
you have 30 seconds....
Old 02-26-2006, 11:02 AM   #5 (permalink)
Member # 44140
....3.....2.....1 uh oh...run! but really anyone know?
Old 02-26-2006, 11:31 AM   #6 (permalink)
Member # 24496
I don't understand what you're describing... take a picture?
NotMatt is offline   Reply With Quote
Old 02-26-2006, 01:22 PM   #7 (permalink)
Member # 44140
I dont have a camera, but it seems like a air chamber, with one hose going to the airbox after the filter, another one that disappears under the intake manifold, and the lower box goes into the intake tube after the mass air flow sensor and has a tube that also disappears to under the intake manifold.
Old 02-26-2006, 01:41 PM   #8 (permalink)
affende's Avatar
Member # 49901
Send a message via AIM to affende
start truck...
pull off part in question...
if it still runs then no, you dont need it
affende is offline   Reply With Quote
Old 02-26-2006, 02:51 PM   #9 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
You do not need the boxes but you need the hoses connected to the intake. It is part of the SMOG system. The boxes are to quite the intake system, with out them when you let off the throttle it will have a gurgling sound. The hoses are the reason that the 3.0 V-6 will Hydro-lock if left on its side to long. I took mine off but did retain the hoses for SMOGing purposes. I do plan on plugging them and running the hoses into a "catch Can" in between SMOG checks. Here are some pictures of what I did.
Remember:
Amateurs ... Built the ark.
Professionals ... Built the Titanic
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/
OOP'S is offline   Reply With Quote
Old 02-26-2006, 05:39 PM   #10 (permalink)
Member # 55921
Send a message via AIM to CRAWLIN4RUNNER
You can take it off as long as you plug the lines. I had to take mine off when I put a k and n cone filter on. i kinda ghetto fabbed the big intake hose till I get some more time to build a new intake tub. I took a rattle can top stuck it in the hole and used the factory hose clamp. I can notice any negative effects.
81 longbed SR5 22r speed
2001 dodge 2500 qcsb
CRAWLIN4RUNNER is offline   Reply With Quote
Old 02-26-2006, 06:00 PM   #11 (permalink)
Member # 44140
okay i bypassed them too, but the smaller one from the intake went to lower box then to the big hole that you plugged with the abs cap. I ran the smaller one to that and then looped the other one, if you plug the larger hose the gurgling sounds go away.
Old 02-26-2006, 06:18 PM   #12 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
But you will not pass smog and can get a ticket for tampering with the emission systems. That is one ticket I do not want to get, I know that it is over $1,000.00 for emission tampering.
Remember:
