steering ram placement? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-24-2006, 09:31 PM   #1 (permalink)
xjoe's Avatar
Member # 46236
Seen a few mounted on a reinforced diff cover. I was also thinking about trying to weld the tabs on the outside of the steering dampner bracket and using the tie rod clamp or welding the tabs on the tie rod. Is there any problem with running it above the axle? Because of the coils, I have nearly no clearance behind the tie-bar at full turn.
Any idea's would be appreciated. Thanks, Joe
FTH-3 Chassis, Tuned 5.3 w/4l60E, Stak, Built 60's. 39" maddogs on 20" Trailreadys...08 Dodge Cummins, 68RFE, EDGE, mp8, Deletes ect...DYNO-497hp/1020TQ
xjoe is offline   Reply With Quote
Old 03-24-2006, 11:57 PM   #2 (permalink)
Member # 56574
This is how I mounted my ram assist, works well. Too bad mine is leaf spring though.
63 Scout 80, 350 sm465 klune 205, 1 tons, 40" Mtr's
scout254 is offline   Reply With Quote
Old 03-25-2006, 09:52 AM   #3 (permalink)
xjoe's Avatar
Member # 46236
That seems to all I can find examples of, Leaf sprung setups. Did a bunch of searching, Does anyone have any examples of steering ram placement on coil sprung axles? Just don't have a lot of room to work with. Any ideas would apreciated. Thanks, Joe
