Can't get thermostat housing to stop leaking - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-05-2006, 09:07 AM   #1 (permalink)
Ol'Customcj7's Avatar
Member # 43637
I have tried 3 different types of gaskets on my housing. And the booger won't quit leaking on the low side. I checked to make sure the metal on the housing was true and straight, as for the block.
What my question is, should I use gasket adhesive? Silicone. I am kind of hesitant to have anything that may break apart and get into my cooling system. My friend says he uses it all the time.
[QUOTE=PAToyota;19894137]Back in college, we were making up acetylene balloons and putting them in a box to take off to light. Guy comes into the room, goes "Balloons!" and grabs a balloon, rubs it on his head, and sticks it to the wall... Everyone was diving for cover... :D[/QUOTE]
Ol'Customcj7 is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 09:10 AM   #2 (permalink)
Twisty4runner's Avatar
Member # 18322
we use the permatex in a can at my shop, seems to work fine for us.
2000 taco
sas'd
36's beadlocked
other goodies
Twisty4runner is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 11:11 AM   #3 (permalink)
Member # 64543
While you are worried about something that may break apart and enter your cooling system, use silicone with good judgement (a thin bead). It's always better than a leaking cooling system.
Bolt Thrower is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 11:21 AM   #4 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Use hylomar
http://www.valco-cp.com/Hylomar.htm
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 12:05 PM   #5 (permalink)
chris408's Avatar
Member # 37354
use double gaskets.
[COLOR="Red"][B]The time is near at hand which must determine whether Americans are to be free men or slaves.[/B][/COLOR]
George Washington
[COLOR="Red"][B]Americans have the right and advantage of being armed-unlike the citizens of other countries whose governments are afraid to trust the people with arms[/B].[/COLOR]
James Madison
chris408 is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 12:09 PM   #6 (permalink)
Member # 44136
Is it one of those crome POS's? If it is, throw it away and use the stock one.
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 12:33 PM   #7 (permalink)
Member # 29638
Send a message via AIM to MuddyV8YJ
you sure you scraped all the old gasket off?
"Life's tough. It's tougher if you're stupid."
[QUOTE=Grim Reaper]Cause of death: Natural selection. :laughing: [/QUOTE]
Girls fake orgasms, guys fake relationships
MuddyV8YJ is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 01:16 PM   #8 (permalink)
Member # 65916
If you want it to really quit leaking.. use 3M Weatherstripping Glue, yes, the yellow snot looking stuff.. it wont leak anymore..
SAEPIUS EXERTUS, SEMPER FIDELIS, FRATER INFINITAS
Truth and Facts, will never get in the way of preconceived opinions.
nagalfar is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 09:15 PM   #9 (permalink)
Member # 67386
Send a message via AIM to HsOffRoad
Before you go fooling with sealant and stacking gaskets... check the simple stuff first. One - Thread the bolts in and make sure they aren't bottoming out before they get tight and clamp the housing. If so, get shorter bolts or stack some washers on top of them so it will generate clamping force. Two -is the housing cracked or chipped? maybee it has a small crack that only allows seepage under pressure, or when the engine is cool & then stops once it's warmed up. Three - are you using the proper gaskets & water neck? Four - are you sure it's the water neck that's leaking, not the upper hose, or the intake manifold itself? Five - Are you tightening the bolts reasonably tight? They don't need to be He-Manned on there, but they can't be finger tight either. Six - Is it an o-ring style water neck? If so, it's designed to work without a gasket with just an o-ring in the groove on the bottom of it. (chances are it still wouldn't leak even if it was installed with a gasket & no o-ring, but you might as well check). If there is an o-ring in there make sure it's the correct one.
Always rule out the simple stuff by imspecting the situation thoroughly before you go spending money and wasting time swapping parts unnecessarily. The thermostat housing is honestly not a very high tech piece of equipment. Clearly something is wrong if it's giving you this much trouble.
Hans
"Shut Up And Wheel Your Junk" - UROC/NEUROC Super-Mod Team #143
HsOffRoad is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 10:30 PM   #10 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
One other thing, are you using a factory style thermostat housing or an aftermarket chrome one? Some of the cheap chrome ones have sealing problems. If this is what you have you need to shitcan it and get one that isn't plated on the gasket surface.
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 06:45 AM   #11 (permalink)
piratebuggy's Avatar
Member # 53597
Use some Permatex Ultra Blue-weatherstrip adhesive softens up and makes a big mess. Why not buy something made for this like Ultra Blue instead of yellow snot?
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 12:16 PM   #12 (permalink)
az79k5project's Avatar
Member # 65515
also check the thermal vacuum switch if your housing has one. Mine was seaping a little biit when i replaced itm and it looked like the housing was leaking. 1/4 turn of the thermo vacuum switch was all it needed.
az79k5project is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 05:03 PM   #13 (permalink)
Member # 29527
It ain't flat. Get a piece of 80-grit sand paper, lay it on a flat surface, and sand that bitch 'till it's flat.
Then, don't use a gasket; use a good silly cone sealant only. A gasket has so much squish to it that it can cause the housing to warp all over again.
FAKE NEWS! A TOTAL PBB WITCH HUNT!
CrustyJeep is online now   Reply With Quote Quick reply to this message
Old 04-10-2006, 02:59 PM   #14 (permalink)
Member # 43637
Unfortunately I have to use a chrome aftermarket. Since it was a boat motor, I had to convert the pulley system. And the brackets now make it impossible to get the stock 45degree to hook up to any hose. So I had to go with a chrome 90degree one.
It's also not the hoses, I watched, it's easy to tell since they are all new, you can easily tell if it's leaking at the hose. Bolts are not too deep I actually threaded them without the housing to make sure.
I checked the housing, it's setup for a standard gasket. I also checked to make sure it's true and straight (enough). I also made sure the manifold was clean and no residual gasket material left. I used one of those 120grit paper blades on the grinder to clean it.
I will try some silicone gasket sealer. That looks like my only option.
Thanks guys.
