Do front brake line lengths have to be equal? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-12-2006, 04:01 AM   #1 (permalink)
knaffie's Avatar
Member # 48084
I'm assuming all the coils in the front brake lines under the master cylinder are to even out the length on each side. Is this correct? Is it necessary to have them the same length? I need to replace one of mine with more of a direct route, but wasn't sure if I could bypass all those coils or not.
knaffie is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 04:47 AM   #2 (permalink)
Member # 16864
I think the coils are mostly for flex between the body and the frame otherwise over time even the slight movement would tend to crack the line so you need flex hose or coiled line you should be fine as long as both tube have same diamater and i could be wrong
69 BRONCO stock p/s a/t 69 BRONCO 4.56 9"spool qjet f100p/s 35s
BnRGEAR is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 05:25 AM   #3 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
BnR has it right - the coils are for stress relief.
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 05:39 AM   #4 (permalink)
knaffie's Avatar
Member # 48084
Okay, then why is there like 10 coils? I guess that makes sense, it just seems overkill.
Old 04-12-2006, 06:52 AM   #5 (permalink)
Member # 68864
Better to have to much than not enough.
MiddleTyger4WD is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 06:58 AM   #6 (permalink)
Member # 37607
Send a message via Yahoo to YZEATER
maybe there was too long of a brake line and they needed to use up some extra length?
YZEATER is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 09:36 AM   #7 (permalink)
Member # 64543
If it came that way from the factory. who knows why there are so many. Manufacturers do alot of silly things. If it was from a PO....
Bolt Thrower is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 09:59 AM   #8 (permalink)
Member # 67386
Send a message via AIM to HsOffRoad
The coils are there to allow the body & frame to flex, as stated earlier. Coiling the lines makes them into springs, which allows movement with less fatigue of the hardline. It also provides a bit of extra fluid capacity in the lines, but that's really a moot point. At any rate, that is why they coiled them from the factory.
As for the length of the lines being equal - no it doesn't matter. once you have the lines bled they are full of fluid, which dosen't compress. Therefore, the fluid in the lines is essentially a solid connection... meaning that regardless of how long the line is, as long as they are full of pure fluid, they will apply pressure evenly.
Hans
"Shut Up And Wheel Your Junk" - UROC/NEUROC Super-Mod Team #143
HsOffRoad is offline   Reply With Quote Quick reply to this message
Old 04-12-2006, 10:10 AM   #9 (permalink)
knaffie's Avatar
Member # 48084
Thanks for the answers guys!
Old 04-12-2006, 10:38 AM   #10 (permalink)
Member # 2790
the more coils you have the less each one moves,,the less it moves the less chance there is of it fatiguing and breaking
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote Quick reply to this message
