Member # 64213
Stop right there.
I see your logic and it won't work; lubrication, steering linkage, etc. are all designed for only one way to install.....right side up.
You may have seen other vehicle components flipped (i.e. Dana 300) to fit a certain application. If you have a chevy 60 and need a driver's drop, either sell the axle (shouldn't be hard to sell a Dana 60) and buy the proper one or research a different transfer case. |
Member # 64230
Yep, use a ford D60. I've seen a lot of them around for cheaper then the chevies, doesn't help me though!!!
Thinking of tearing out that twin traction beam garbage? Remember to map out your entire build 1st before you start tearing into things. I thought I did a great job of that on my current build and them when I went to install my 4:1 case I just got from marlin I realized that UPS had bent the shift fork!!! That was after I dropped the t-case on my daily driver. Keep us informed on what you're planning.
Member # 68512
one thing that has not been mentioned is, if you did flip it over, the wheels would turn the wrong way.
i have actally had this idea for a rear steer idea. using a front end in the back, flipped over. you would have the steering issues and oiling to deal with though.
89 s10, flogged regularly 94 burb, tow rig |
#5 (permalink) | |
Member # 1635
See how the bottoms of wheels facing the desk are now turning the wrong way? If you want to re-tube there are threads and articles on this, but you’re best to sell you axle and get the correct one.
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
#6 (permalink) | |
Member # 1635
Ok, seeing as this is something done all the time in comp buggies, I can give you a brief rundown of the 3 main issues you will encounter when flipping an axle housing:
1 - Gears - The gears are now set up so it will rotate backwards. This works great for rear engined buggies with the motor backwards, but to use the setup in a front engine application, you need to install a set of opposite cut gears. For instance, if you flip a chevy D60 for use upside down in a front engine application, you need to use a set of reverse cut D60 gears from a ford to make it spin the correct way. A flipped ford HP will require a set of regular cut chevy gears. Also note that when you flip a chevy D60 it becomes high pinion... if you flip a ford D60 it becomes low pinion. 2 - Steering - The steering knuckles are now upside down. Not only will it not steer properly this way, it won't take the load generated by the weight of the truck resting on it. To get around this, you need to cut the "C"s off and re-attach them flipped 180 deg. (or whatever you need to get caster correct after you set your pinion angle). By the same token the breather is now upside down & needs to be welded shut & a new one drilled & tapped in what was previously the bottom of the housing. 3 - Oiling. The Ford D60 should work just fine run upside down as a low pinion, since the pinion is going to be more ore less bathed in oil at all times. Of course, this defeats the purpose of having the high pinion, but if you're considering flipping your axle apparently you have your reasons for doing so. The chevy low pinion D60 will have pinion bearing oiling issues with extended high speed use, but it will work fine for low speed off-road only operation. You can also overfill the unit through your newly made breather hole, which helps combat this issue somewhat. Now, for my opinion on doing this to save money... no way. After all the fab & mechanical changes, you are way past the cost & aggravation to find the correct D60 for your vehicle. I agree, that the ford D60 outers aren't as nice as the chevy units, and the high pinion ford centersection is a plus for a front engine truck. Ultimately, the best axle would be a combination of the ford HP housing, with chevy knuckles & outers. Even if you had to retube the axle or swap out your transfer case that would ultimately be the way to go (at least as far as stock D60 parts are concerned). Once you open the door to fabricating an axle assembly, anything goes... why not use a ford 9" center, or a 14T... or graft the rockwell outers onto one of these. Don't lose sight of the fact you are looking for a simple bolt in swap that will give you the strength you want. Things snowball in a hurry otherwise. Hans
[B][FONT="verdana"][SIZE="3"][CENTER]"Shut Up And Wheel Your Junk" - [url]www.hsoffroad.com[/url][/CENTER][/SIZE][/FONT][/B] [FONT="Verdana"][CENTER][SIZE="2"][B]UROC/NEUROC Super-Mod Team #143[/B][/SIZE][/CENTER][/FONT] |
#8 (permalink) | |
Edit: I now have no problem saying your wrong, my little quick search confirmed what I had initially thought. YOUR WRONG, know your stuff before you give advice, otherwise we just wind up with more people spreading false information and making the rest of the world dumb too. http://www.pirate4x4.com/forum/showt...nion+low+gears http://www.pirate4x4.com/forum/showt...nion+low+gears http://www.pirate4x4.com/forum/showt...nion+low+gears http://www.pirate4x4.com/forum/showt...nion+low+gears
The mountains are calling and I must go. -John Muir Last edited by currupt4130; 04-20-2006 at 08:14 AM. |
OK, I stand corrected about the ford gearset in the chevy housing making them spin backwards. Under examination of the 2 housings, what they did with the Ford High Pinion is move the pinion location to the opposite side of the ring gear, allowing it to spin forwards even when it is located above the axle centerline.
That is a misconception I have been operating under for quite some time. I obviously never attempted it myself, since I have had no reason to, but I have been told by many reliable sources that that would work, so I never took the time to look into it myself, just took it as fact. Guess that goes to show what you get for taking things as truth without testing it firsthand. It's an easy misconception to believe and not feel the need to question further, since if you look at the parts books, all of the parts interchange except for the R&P... The carrier, the bearings, etc. are all the same. SO you figure... "OK, the reverse cut R&P makes it spin backwards.. that's why they use them in the HP front axles". Not so. It's not the angle that the teeth are cut on that makes it not work, it's the location of the pinion in the casting, relative to the ring gear. Perhaps you could somehow make it work by clearancing the housing & shaving the ring gear to run the carrier backwards, but that would sure be a hell of a lot of work. Even then, getting the gearsets to mesh without moving the ring gear mounting surface on the carrier would be an issue, most likely an insurmountable one. The point is no one needs to figure out how to do this anyway, because it's pointless. I do have first hand experience building rear engine vehicles with flipped regular cut axles. I can say for a fact that the axle will rotate backwards when you run a standard axle as a high pinion... due to the pinion being above the axle centerline but still on the same side of the ring gear. That much I can say as hard, tested fact... as well as all the other information in the post (with the exception of swapping gearsets to change direction). I wouldn't say operating under the idea that swapping gearsets would work classifies me as dumb. If so, then quite a few of the top 4wd shops & competitiors I know are dumb as well. I agree that in this instance, I was in the wrong and it should be corrected before others get the wrong idea from the misinformation. I have no issues taking my lumps when I make a mistake. I know I've corrected people many times in the past myself... and this is pirate board. Appologies... Hans
[B][FONT="verdana"][SIZE="3"][CENTER]"Shut Up And Wheel Your Junk" - [url]www.hsoffroad.com[/url][/CENTER][/SIZE][/FONT][/B] [FONT="Verdana"][CENTER][SIZE="2"][B]UROC/NEUROC Super-Mod Team #143[/B][/SIZE][/CENTER][/FONT] Last edited by HsOffRoad; 04-20-2006 at 11:56 AM. |
I think a quick answer of no would have worked....Haha, I love you guys here, because you know there is always someone that once they read no, they think it will still work, and so you have a explain why it WON'T work.
Thanks guys, I was at the junk yard and saw a most all the dana's out there for Chevys, so I figured I'd ask. Thanks. |
#11 (permalink) | |
Member # 1635
and don't foget my post about who to trust.
#13 (permalink) | |
Member # 23262
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer, English Philosopher (1820-1903) |
#14 (permalink) | |
Member # 1635
#16 (permalink) | |
Member # 1635
#17 (permalink) | |
The mountains are calling and I must go. -John Muir |
