14B Brake questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2006, 12:40 PM   #1 (permalink)
Bluebeast393cid's Avatar
Member # 29382
14B Brake questions
Ok i started to pull the 14B apart today and got all the retaining nuts and washers out. I can see the outer bearings but for some reason cannot pull the hub and drum off of the spindle. Trying to do this to do the brakes on this axle before I plant it in my truck.
so..
1. How does the drum and hub come off of the spindle pnce all the nuts and washers are off of it.
2. Is there any exploded view of the rear brakes? I could not find on in the 14B bible
Thanks again
JP
90 Bko 393W/E4OD/BW1356 60/14 4.10s 4D2s
Bluebeast393cid is offline   Reply With Quote
Old 04-25-2006, 12:54 PM   #2 (permalink)
Member # 68512
you probably have to back off the adjusters on the brake shoes. if they are stuck, this is a real PITA. i had to slip the blade of a sawzal in thorough the backing plate and cut them in half to get my drums off.
89 s10, flogged regularly
94 burb, tow rig
Donahue is offline   Reply With Quote
Old 04-25-2006, 01:04 PM   #3 (permalink)
Member # 29382
but the drums seem to rotate freely w/o any drag on them. i didnt think that this would be an issue but then again i havent worked on a FF before
Old 04-25-2006, 01:16 PM   #4 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Read his post again. What he's telling you is that the brake shoes have worn
the inside of the drum and that there's a "lip" on the inside edge of the drum.
This will keep you from sliding the drum over the shoes. Ask me how I know.
SanDiegoCJ is offline   Reply With Quote
Old 04-25-2006, 01:34 PM   #5 (permalink)
Member # 49914
he's right.
I had to take a BFH to mine and pound the crap outta them to knock em off. Totally sucked.
Where a mask. Whole bunch of brake dust goes into the air when you do it.
2LoudDodge is offline   Reply With Quote
Old 04-25-2006, 04:22 PM   #6 (permalink)
Member # 29382
ok CJ i got it.. overlooked thatfrom the original. thanks
Old 04-25-2006, 05:20 PM   #7 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
my 14b had the brakes cooked onto the drums or something, took me a 2 guys 3 hours with a BFH to get them off, but the lip will stop you no doubt and if you use a BFH be prepaird to buy new drums
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
Old 04-25-2006, 09:00 PM   #8 (permalink)
Member # 68512
its cheaper to go disks than rebuild drums. it lease it was for me.
94 burb, tow rig
Old 04-26-2006, 04:37 AM   #9 (permalink)
Member # 50360
yeah its $110 for 77 k20 rotos, calipers, brake pads, $210 for drums, hardware, shoes. that was the first mod i did to my 14b when i got it cuz the drums were toast and i didnt have $210
Old 04-26-2006, 11:03 PM   #10 (permalink)
AF6 OD
R290's Avatar
Member # 46467
Here is your expolded view
14 bolt
It takes two small screw drives to release the adjuster. One to lift the arm and the other to turn the spiked wheel. left hand thread. turn the little wheel with one screw driver ( click click) know you know it needs to go the other direction. using the second screw driver to hold arm off the little wheel.
I know this is basic stuff, but thought it should be mentioned.
R290 is offline   Reply With Quote
