Member # 70026
86 Runner "clicking" instead of starting.
My neighbor has an 86 with a 22 RE and about 175,000 miles.
Lately he has been going to start it, and it just clicks. If he keeps trying, it will eventually start. He did it for me an hour ago.........one loud click for each turn of the key. This is after he replaced the perfectly good starter with one from NAPA. (why do guys always do that.........well, they are young guys that just party and drink beer) It still does the exact same thing. So what is your advice? I know that someone here knows what it is exactly. Thanks, MrMoose |
Did he buy a brand new starter, or did he buy a rebuilt starter? Sometimes they come faulty from the factory, I've had it happen several times-
![]() This sounds EXACTLY like a faulty starter.
[QUOTE=300sniper]i think that is why they give the guys in old folks homes viagra. it keeps them from rolling out of bed at night.[/QUOTE] |
Member # 70026
He says that it is a brand new starter, not rebuilt. He paid $117 for it, with a $20 core charge.
He also says that the clicking is coming from a small box on the passenger fender wall. Could just a loose battery connection do this? MrMoose |
#9 (permalink) | |
Member # 19077
yotamasters.com <-------- NEW WEBSITE IS HERE!!!!! |
#10 (permalink) | |
Member # 19077
#12 (permalink) | |
Fab Fanatic & RC
Member # 5342
Location: Mid CA West Bay Area next to NASA Jet dudes! 3hrs to RUBICON!!
pull off and clean with baking soda and water or wire brush it Replace positive battery clamp with a new one
1/8 Scale Rock Crawler DIG MP3 Player, PICS on Pirate RC Rock Crawler Tube buggy with DIG , MP3 stereo 85 4Runner 92 4runner YouTube - Street Luge Cam Ohio Rian |
#13 (permalink) |
Member # 70563
Mine did the same thing.... it might be the starter wires. If there is oil or dirt on the wires/connections/or bolts you will get this. Get in there and shimmy the starter around and it will work. A little bit of brake clean on them and it should be good. Usually only happens when cold.
a toyota truck. |
#16 (permalink) |
Member # 64240
For the mileage on it id say x2 on the starter contacts. real common thing i see at the shop and they cost around $25 any dealer should carry them. Take off the back plate of the solenoid and remove the plunger (just pulls out) you'll see the contacts at that point.
#18 (permalink) | |
Member # 4716
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest Replacement contacts are available for about $5/ea., if needed, or it may be a wiring or relay issue: - http://www.4crawler.com/4x4/CheapTri...l#OtherOptions |
#20 (permalink) |
Member # 37212
I have the same problem. Only happens when the truck is cold. Its NOT the battery connection. All I do is short the posts on the starter and it starts right up. I need to pull it and clean or replace those contacts. Once my truck is warm, it starts up flawlessly every time.
Chass ct
Tuna! |
#21 (permalink) | |
Grocery Getter
Member # 59
![]() That could be the problem as well. It makes it look like the starter is bad when in fact it may not be. Similar symptoms as the starter solenoid contacts being worn. |
#22 (permalink) |
Wicked Raciest !
Member # 30
nineteen posts and not one mentioned the starter realy until Beebs came along. There are three or four say it is the contacts get new ones, it is a rebuilt starter, they should be fine. My bet like Eriks it is something to do with the starter relay. That is what it was on mine and I just bypassed it with a Ford solenoid and a push button. It has worked fine ever since!!!!!
David & Theresa, Roseville, CA, Remember: Amateurs ... Built the ark. Professionals ... Built the Titanic http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/ Last edited by OOP'S; 05-19-2006 at 02:50 PM. |
#23 (permalink) |
Banned
Member # 25234
My uncle was having the exact same symptons with his 2wd DD. Accessories worked fine. He cleaned his battery connections, but would still do it periodically. I told him I thought it was his starter and he didnt want to deal with putting a new one in. He bought a new battery just to try it because it was easy. Hasnt had a problem since.
*edit* scratch that... just talked to him. It has done it one more time to him in the last month. Last edited by Aaronius; 05-19-2006 at 02:59 PM. |
#24 (permalink) |
The People saying it is the contacts are wrong. Its the relay.
Steps to fix. ( i did this yesterday) 1. Get a screwdriver (+) head. 2. take the glovebox off. 3. get a rachet and 10mm socket. 4. stick you head in where the glovebox goes and you'll see on the pass.side of the firewall more the side wall there is a big relay. (its says something like STARTER RELAY go figure) 5. take the socket and take that relay out. 6. Replace with new on of one that is off another junker. (i think new it would be somewhere around 100 bones, Hell the flasher relay from toyota is 59 bones.) 7. Try starter. It should work fine. 8. bolt back on to the firewall. 9 put the glovebox back on. 10. your done. Now your headache should be over. Dan
Project JAIL BAIT Last edited by Wild_yota13; 05-19-2006 at 04:05 PM. |
#25 (permalink) | |
Member # 4716
![]() Any more than about a 0.5v drop (under load) and the problem is likely between the starter and the battery. |
