Easier Locker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-05-2006, 07:13 PM   #1 (permalink)
Member # 67499
Easier Locker
Whats an easier locker to install with minimal tools, one that replaces the carrier (detroit), or one that goes into the carrier (lockright)? looking forward to what would be easiest to install, anyone know from experience?
GM4Life is offline   Reply With Quote
Old 06-05-2006, 07:47 PM   #2 (permalink)
Member # 72257
Any of the lunchbox lockers are going to be the easiest (Lockright, Noslip, etc.). If you have to replace the carrier (ARB, OX, Detroit full lockers), your looking at setting up the gears again. World of difference in simplicity.
I drive the fastest barbecue on 4 wheels...
CJim7 is offline   Reply With Quote
Old 06-05-2006, 08:04 PM   #3 (permalink)
Member # 67882
Just get the welder out thats the easier one lol
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote
Old 06-06-2006, 07:07 AM   #4 (permalink)
Member # 50730
X2
TANNERJENNINGS24 is offline   Reply With Quote
Old 06-06-2006, 04:37 PM   #5 (permalink)
Member # 67499
so is anyone running a welded front on and off road?
Old 06-06-2006, 08:59 PM   #6 (permalink)
tennessee rockhumper's Avatar
Member # 52201
sure, as long as you have selectable hubs for the street.
tennessee rockhumper is offline   Reply With Quote
Old 06-07-2006, 03:31 PM   #7 (permalink)
Member # 67499
so whats the difficulty from worse to easiest between lunchbox locker, carrier locker, welded, spool, and mini spool?
Old 06-07-2006, 06:21 PM   #8 (permalink)
Member # 69347
welding isn't just busting out the mig and pouring some wire into it, to be done the right way the carrier has to be preheated and then tig welded and then either wrappe in a blanket to cool slowly or buried in special sand or put into a special oven, not that easy, better off getting a spool so it can be undone later
i'd say welding them properly is harder than setting up gears properly, but i have setup prolly 50 sets, nothing is really as cut and dry as it seems
Brendan
sha_ba_do_bang is offline   Reply With Quote
Old 06-07-2006, 08:13 PM   #9 (permalink)
Member # 67499
that blows. so if you dont let it cool slowly it gets really brittle kinda like when working with glass, huh?
Old 06-09-2006, 08:16 PM   #10 (permalink)
Member # 52201
B.S. --in a perfect world yeah, whatever, he is technically proper, but dont let him scare you.
if you mig weld the shit out of it, with good beads, use plenty of wire, and catch all the surface area you can, it will hold just fine. i have shattered ring and pinions, and twisted axle splines, and the 30 minute mig job i did has never failed.
to answer your question: 1.welded, follwed by 2.lunchbox and/or minispool, then 3. spool and/or carrier lockers
Old 06-09-2006, 09:09 PM   #11 (permalink)
Member # 69347
alright, whatever, it will look like a wad of shit and you just ruined your carrier and spiders, i would get a spool just to save the carrier in case you ever want to go back
and you won't really have good luck mig welding it, it really needs to be tig welded with preheating, but nigger rig it if you want to
Brendan
