length of u bolts toyota - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-12-2006, 03:10 PM   #1 (permalink)
Member # 35093
What is the length everyone is using for their U-Bolt flip kits? I know they are 9/16" diameter. But what about the length? This would be for a toyota rears up front with stock 85 axle, and an IFS rear 88 axle with 63" chevy springs if it makes any difference.
What length of U bolts should I get?
Thanks
It isn't real body damage unless dent removal involves a tractor. - TNTOY [03/23/06]
youngladdy is offline   Reply With Quote
Old 06-13-2006, 07:08 AM   #2 (permalink)
Member # 35093
FROR's kit comes with either 7 or 7.5" long ubolts. What size is better? Should I look for longer ones just incase I add more leaves to the spring back in the future?
They are also 3.0 or 3.5 inches wide, what is the difference? Are the 79-83 axles a smaller diameter?
Thanks
Old 06-13-2006, 07:11 AM   #3 (permalink)
Member # 35093
Also, where is a good place to purchase the u bolts inexpensively?
Thanks in advance.
Old 06-14-2006, 11:25 AM   #4 (permalink)
Member # 50033
Send a message via Yahoo to yamxer438
measure for the size you need, scroll to the bottom of the link below, find the ubolt that matches somwhere close, go to napa tell them what u you need. they are fairly inexpensive
http://www.gorancho.com/products/app...ifications.pdf
83yota, smoke stack exhaust, 5:29s, int roll cage, marlin x over steering, detroits f/r, not so smart man behind the wheel
yamxer438 is offline   Reply With Quote
Old 06-14-2006, 03:27 PM   #5 (permalink)
Member # 35093
I can't measure yet because I don't have the springs or axle ready. I just was hoping someone new and could tell me.
Thanks
