front calipers. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2006, 03:26 PM   #1 (permalink)
Member # 67740
front calipers.
I have an 86 GMC 1/2 ton.Swapped the engine from V6 to V8,and the tranny from 700R4 to Sm465 with a 205.
I'am now putting in a 44 front and 14 bolt rear and i'am just wondering if i can use my 1/2 ton calipers on the 44 backing plates,or if i have to switch those as well.
Thanks
purplehavoc is offline   Reply With Quote Quick reply to this message
Old 06-21-2006, 08:46 AM   #2 (permalink)
jesster's Avatar
Member # 49468
Not sure if you can use 1/2 ton calipers on 3/4 ton backing plates. I am leaning towards no, but check and see.
Also, I think that in order to run 1/2 ton backing plates and calipers on an 8 lug 44, you will have to have the 3/4 ton rotor machined down to 1/2 ton diameter.
But I am not positive about any of this...
jesster is offline   Reply With Quote Quick reply to this message
