D60 crush sleeve nightmare. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-08-2006, 05:43 PM   #1 (permalink)
Member # 44416
d60 rear, is it Necessary to run a crush sleeve? I cannot get the sleeve to crush, I've used my big matco 1/2" impact in the axle to no avail, put the yoke in a vise to try and start it crushing and move it back to the axle to no avail as well. This thing will not budge. Can I set-up the gears without it?
Yes everything is in the correct spot and in the right direction.
034x4 is offline   Reply With Quote
Old 08-08-2006, 05:47 PM   #2 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
we use the 1" impact that we use to take off semi wheels, crushes like nothing
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
Old 08-08-2006, 06:13 PM   #3 (permalink)
Member # 23853
Send a message via AIM to DarkEternal Send a message via Skype™ to DarkEternal
You dont have to run a crush sleeve if you dont mind your pinion bearings failing in a few miles.
Put the sleeve in a press to get it started, crush it literally only a few thousandths. Once its started it should be easier to crush a bit more to get proper preload.
DarkEternal is offline   Reply With Quote
Old 08-08-2006, 06:27 PM   #4 (permalink)
Member # 69347
i haven't had luck with the press, it always ruins it, you need to run it and i have never gotten it to crush with an impact
ususally the 3/4" breaker bar with a 6' extension does the trick
good luck
Brendan
sha_ba_do_bang is offline   Reply With Quote
Old 08-08-2006, 07:08 PM   #5 (permalink)
Member # 13786
You don't need the crush sleeve to set/adjust the gears. I would do that after everything is set-up
KWTMECH is offline   Reply With Quote
Old 08-09-2006, 06:39 AM   #6 (permalink)
Member # 44430
I've never seen a Dane 60 with a crush sleeve. What year is it ? Semi float ? Full float ?
79 F-250 4x4 12" lift 42's
Dr.Doom is offline   Reply With Quote
Old 08-09-2006, 01:07 PM   #7 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Heat it torch, just to warm it up, toss it in, toss outer bearing it, yoke, but and start to crush it.
Mark
welndmn is offline   Reply With Quote
Old 08-09-2006, 01:27 PM   #8 (permalink)
GiS
GiS's Avatar
Member # 31285
I had a "crushed-crush sleeve" made by EVO, ...
Randy's also sells em..I just fawking HATE crush sleeves,.
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote
Old 08-09-2006, 06:39 PM   #9 (permalink)
Manson's Avatar
Member # 37512
I have a 5' bar I bolt to the yoke and use a breaker bar with an extended handle to crush these, a 1/2" air gun usually won't work. Be sure to grease the nut and washer so everything turns easier, this actually makes a big difference. Sometimes I have to use the press first also but can distort the sleeve if not carefull.
94 4Runner, solid axle swap, 3.4 swap, ultimate crawler, one tons, 39.5" iroks
Manson is offline   Reply With Quote
Old 08-10-2006, 11:31 AM   #10 (permalink)
4x401cj's Avatar
Member # 37244
I`m curious to know what Dana 60`s ran a crush sleeve, `cause I`ve never seen one
4x401cj is offline   Reply With Quote
Old 08-10-2006, 04:53 PM   #11 (permalink)
oldrivers's Avatar
Member # 28570
Some of the aftermarket gear sets use them.
oldrivers is offline   Reply With Quote
Old 08-10-2006, 07:15 PM   #12 (permalink)
Member # 44430
Why not just order a regular set without one ? Is there a case difference in some years ?
Old 08-10-2006, 07:59 PM   #13 (permalink)
Member # 13786
A lot of the 5.38 gear sets that I have installed have them
Old 08-11-2006, 08:53 PM   #14 (permalink)
Member # 44430
I wouldn't have a crush sleeve up my ass. There has to be a way around it..
