Member # 63741
well if i go with injectors its between these two. but i dunno the difference
http://store.summitracing.com/egnsea...115+4294908000 |
AZ Undertaker
Member # 51580
Well, it depends. What motor are we talking about? And is this a 1/2ton Burban with the explosive 10 bolt?
MILLER RACING #26 2012 Dirt Riot Modified Trail Class Champion ADS SHOCKS * ARTEC INDUSTRIES * SOUTHWEST FASTENER * HOWE PERFORMANCE * RUGGED RADIOS * SDHQ * BLACK N BLUE RACING * RIGID INDUSTRIES * CAMPBELL ENTERPRISES * LETZROLL OFFROAD |
Member # 63741
ok well heres a question then. say i put a 14boltff on the back. i need 8 lug on the front correct? well when i change the hub to and 8 hole hub are the bearings going to fit from the 6 hole? or am i going to have to change everything internally? or would i b better off building the 10bolt. or just getting a 14bsf?
#7 (permalink) | |
Member # 19443
I'd do injectors. Locker's no good if your truck burns to the ground.
bigredblazer@gmail.com <>< |
AZ Undertaker
Member # 51580
I just converted my 44 to 8-lug and put a 14 bolt out back. I had a 12 bolt in my Suburban, which is slightly better than the 10 bolt, but still sucky. I blew that thing up 3 times in 3 trips and said, screw this, I'm getting a 14 bolt.
Member # 63741
VNM-HP645-800-2
VNM-HP645-800 those are the part number to the injectors. when u put a 14 bolt in back what all do u need to change? shock mounts right? but do u grind off the mounts on the axle or the ones on the frame? and the brake lines should fit correct? |
Member # 39414
It's easier to change the shock mounts on the axle
1994 sas, pro comp remote resevior 14", chevies in the rear and trail gears 5" springs up front 1980 pickup - the new project |
skullfuckery
Member # 29016
shock mounts are all the same spot. you WILL need to mix match ujoint or get your drive shaft redone for the 1350 joint at the axle.
if you get a complete 14bff[with ebrake short cables] it is a dirrect swap!!! as for your front 10b, yes your bearings and spindles are the same, you WILL need the rotoating hub[not the locking hub it is the same too], rotor, and brake caliper backing plate/mount from the 3/4t axle as for the your question, get the most expensive one done first so its easier to do the other later.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP Last edited by trkklr77; 08-20-2006 at 11:15 AM. |
