TSL vs Irok - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-21-2006, 07:26 PM   #1 (permalink)
Member # 11985
Send a message via AIM to 1TFROT
TSL vs Irok
ok, I might as well post this since there's tons of people here who have run both and/or will have a good answer for me
here's my small dilema.....
I'll be needing new tires fairly soon and have pretty much narrowed it down to 2 choices. these are based pretty much on price and size. I have the 37x12.5-15 MTRs now and really like them. but, I want something a little bigger for the next set. so, I'm looking at the 38" TSL (bias) or the 39.5" Irok (again, bias).
here's where I need the opinions. I know what I should do, but it's a tough call. they both weigh the same (within 4lbs of each other), but the TSL is 12.5" wide and the Irok 13.5" wide
this will be run on a D44/9" setup (current setup with the 37" MTRs) and also have Yukon shafts front and rear. dual locked (lockright/spool), 4.88s, close to stock 4.3 on a 5k rig (s10).
most of the wheelin is midwest like the badlands so the trails have everything and typically are damp/wet due to rain.
both axles have held up extremely well with the 37s. so, do I go with the 38s or is the jump to the 39s doable without getting too over the line? I push the truck hard, but try to always wheel smart with a light foot (unless otherwise needed). this is a DD so that might play a huge factor as well since I hear the Iroks wear extremely fast on pavement.
I know the whole "get a D60" thing, but it's not in the budget now.
thanks for any opinions
fawk this, let's go wheelin
1TFROT is offline   Reply With Quote
Old 08-22-2006, 08:09 AM   #2 (permalink)
Member # 47246
Send a message via AIM to NHRedneck
if you can afford a set of tires, then you can afford a D60..... and just buy a used set of tires to get you by for the moment..... then you cna buy the 39" iroks....... and if its your DD then you should be thinking about radial iroks.......
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 : [url]http://www.cardomain.com/ride/2145548[/url]
Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 : [url]http://www.cardomain.com/ride/393604[/url]
NHRedneck is offline   Reply With Quote
Old 08-22-2006, 08:16 AM   #3 (permalink)
Member # 39371
Send a message via AIM to currupt4130
TSL's if it's still a part time DD, and sipe them heavily if its mainly wet stuff
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote
Old 08-22-2006, 08:31 AM   #4 (permalink)
AZ Undertaker
theydontstop's Avatar
Member # 51580
I don't know what rims you have now, but 39.5 Iroks are more in the range of 15" wide. On a 10" wide rim I measured a set at 15 1/4" wide from sidewall to sidewall. Iroks are gonna wear faster. x2 for the TSL's if it's still a DD.
MILLER RACING #26
2012 Dirt Riot Modified Trail Class Champion
ADS SHOCKS * ARTEC INDUSTRIES * SOUTHWEST FASTENER * HOWE PERFORMANCE * RUGGED RADIOS * SDHQ * BLACK N BLUE RACING * RIGID INDUSTRIES * CAMPBELL ENTERPRISES * LETZROLL OFFROAD
theydontstop is offline   Reply With Quote
Old 08-22-2006, 10:38 AM   #5 (permalink)
Member # 30001
I just drove my vehicle for the first time with my Bias Iroks, only 36's though, and they were amazingly smooth.
I had some LTB's that felt like octagons or something before.
samwe is offline   Reply With Quote
Old 08-22-2006, 11:00 AM   #6 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
^It's not the fact that the tsl's feel better on road...they don't--though the iroks are still made by interco--there's still a 50% chance they won't be round. It's the fact that the iroks wear faster and have much less tread depth so that pretty quickly you'd be looking for a new set of tires.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 08-22-2006, 12:17 PM   #7 (permalink)
Member # 30001
Oh I see, do the radials wear slower then?
Old 08-22-2006, 03:12 PM   #8 (permalink)
Member # 78049
tsl
the tsl are bad ass but mine only lasted 6 mounths but i wheeled every weekend with them and drove like 20,000 miles on them,
mustsellxj is offline   Reply With Quote
Old 08-22-2006, 03:13 PM   #9 (permalink)
Member # 78049
tsl
mine were the biasply the were so good off road!
Old 08-22-2006, 05:22 PM   #10 (permalink)
Member # 77302
tsl vs irok
here is my 2 cents, I have the interco trxus m/t's on my yota, haven't had them in alot of mud or trails yet, but since you live in chi-town and you use this as a dd here is something to consider. I had them on a 87 fullsize dodge ram 4x4 and they were wearing great, they are awsome on ice and snow, and they ride well-better than the michellins(street tires) that are on the dodge now. These tires are not that noisey, if thats a concern, not bad on price either. It's just my 2 cents, but I love these tires on a dd.
gonepostal is offline   Reply With Quote
Old 08-22-2006, 05:30 PM   #11 (permalink)
Member # 69245
The trxus m/t's come in a 38.5, too. I would get either those, or the tsl's. 39s on a locked d44- I am sure it would work (and has), but you can't spend a lot of time fixing this thing since it is your dd. Plus they wear fast(er).
outlaw.308 is offline   Reply With Quote
Old 08-22-2006, 06:43 PM   #12 (permalink)
Member # 11985
thanks for the replies so far, I appreciate it.
I'm leaning towards the TSLs as of now and probably will stay with those. I will look into the TrXus MTs since I know they are a pretty nice tire. if they stick as well to the rocks as the MTRs, then I'll be happy. I'm pretty sure the TSLs will hook up as well as the MTRs and that's one thing I don't want to sacrifice since I mostly try to stay on the rocks.
any idea if the sidewalls for the TrXus MTs are as strong as the MTRs (since we know the TSLs are strong as hell)
edit* just checked Interco's site and the largest 15" they make is the 37x12.5-15 which is what I have in the MTR. I'd probably rather go with another set of MTRs if I don't go bigger.
Old 08-24-2006, 08:57 AM   #13 (permalink)
knaffie's Avatar
Member # 48084
Steve, in the research I did, people were reporting life of between 5000 and 20,000 for bias Iroks. No reported cases of any more than that 20,000. Iroks are definitely sticky, but at the sacrifice of life. Not sure about the radials becuase hardly anybody is using them. And a lot of guys on here selling their 39.5 Iroks and going 40" MTR because or the Iroks's poor road manners and noise.
2011 TTF buggy
knaffie is online now   Reply With Quote
Old 08-24-2006, 09:32 AM   #14 (permalink)
Member # 11985
thanks for the info Chris. I'm guessing I'll go with the TSLs just for longevity on the road (that sounds funny!). I wouldn't go radial Irok due to price and I actually looked at the 40" MTR (getting new steel wheels too) and they are way too much for me.
looks like TSLs most likely and then once I go one ton, maybe step up to the 42" TSLs
