Mr. Personality
Member # 11869
It is not hard. If you have the time and place to do it , id say go ahead.
Just did one in my dads 78 cj5 , nothin to it. Make sure you get the flywheel resurfaced while its apart and replace the pilot bushing in the rear of the crankshaft , as well as the throwout bearing. Check all your clutch linkages and bushings also , they are cheap to replace and will improve the feel of the clutch if it had a lot of takeup or slack before. This would be a good time to reseal a leaking transmission or t-case and to change out driveshaft u-joints , replace transmission mounts. PM me if you need any torque specs or advice. |
drop the t-case and tranny, have a buddy to help, these are heavy and very hard to work with alone, pull off the presure plate, remove pilot bearing/bushing, put in new pilot bearing/bushing, install new clutch disk and presure plate with the little alightnment tool they give you, put in the new throw out bearing, reinstall tranny and t-case. all done
dont forget to get he flywheel cut if its needed, ive seen guys get away without cutting the flywheel but i always have it done
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI Last edited by NetBSD; 08-31-2006 at 09:56 PM. |
