International Dan
Sodium filled valves?
I know wheeling and I know 4 wheel drives, but I dont know engines. What does sodium filled valves mean? I got salt in my valves? What for and why then?
Thanks
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
Mr. Personality
Member # 11869
The stems are filled with sodium , then the valve head is spun at an extremely high rpm and pressed against the stem to fusion weld them together.. at least this is how mercedes does it.
It helps to keep the temperature of the valve head down , but transfers it to the stem and cylinder head. |
International Dan
Do all engines have them now, or is it a high end engine type of thing?
#4666 build http://www.pirate4x4.com/forum/showthread.php?t=1048195 facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
Mr. Personality
Member # 11869
A lot of engines use them now , not sure if they ALL use them.
Lycoming used them in their aircraft engines , and had trouble with valve guide heat soak and premature wear because of innadequate oiling near the guides in the cylinder head to cool them. The sodium transfers the heat up the stem into the guide and cyl. head and has to be air or oil cooled. |
#5 (permalink) | |
Member # 55805
Busted sodium filled valves or cutting into these valves can be dangerous. Sodium (at room temperature as it would be before you start cutting on a valve stem) is a soft lustrous solid. You can cut Na easily with a table knife. When exposed to air, it rapidly starts to corrode. This corrosion is quite exothermic and causes the temperature of the Na to increase. The higher temperature causes the rate of corrosion (oxidation) to increase thus causing the temperature to rise even more rapidly. It can become quite a cycle. The metal can ignite in a shower of molten burning sodium metal. Quite spectacular. Na is also extremely reactive with water. A small pea-sized lump placed in water produces enough heat to melt the sodium metal as it dances around on the water surface while it reacts. Again, quite a demonstration. If a large enough piece is dropped into a bowl of water the sodium can get hot enough to ignite the hydrogen which is produced and cause a similar spectacular display. Bits of molten flaming sodium sticking to the ceiling. |
International Dan
thanks. that helps a lot. note to self...dont cut valves.
#7 (permalink) | |
:laughing: |
Member # 73066
having sodium filled exhaust valves helps keep the valves cooler during the ignition stroke of a an internal combustion engine. how it achieves this i don't know. the cooler the valve the more it is less prone to pre ignition or pinging on cheep gas, also the cooler you are able to maintain the valve the better it will react to higher compression with the same valve without sodium filled valves. did i make sense? probably not... i drinking some bacardi mango rum drink that my wife just hooked up.
i have them in my corvette equiped fast burn headed 406. i love this engine. |
#10 (permalink) | |
Mr. Personality
Member # 11869
International Dan
Yeah, my buddy bought a new Z06 vette and they talked up the sodium valve thing. Hand built 427 505hp, 0 to 60 in 3.4, 0 to 100 in 7.4, sodium valves, etc... thats what got me wondering.
#13 (permalink) | |
International Dan
#14 (permalink) |
Member # 40230
I started wrenching on cars with volkswagens. The Corrado to be exact. My stock engine in there was a 1.8l supercharged engine with the sodium filled valves. I had a friend do a test on them with and without sodium filled valves on the dyno. Sodium filled valves netted just over a 5 whp and 7 wtq gain. I will never build another engine without sodium filled valves.
-Greg
Toys and Tools |
#15 (permalink) |
Member # 40230
-Greg
Toys and Tools |
#16 (permalink) |
Member # 65411
gives me the shits just thinking about sodium in an engine. one little leak and your engein will pretty much blow up.
almost as scary as the liquid sodium that cools nuclear power plants (or used to- think they still use sodium). This dosium flows at hundreds of degrees F and then exchanges with a water filled heat exchanger- aain one little leak and you have enough hydrogen to blow up america! |
