running a truck without headers/exhaust? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-07-2006, 12:29 PM   #1 (permalink)
Member # 76389
besides the noise, is there anything wrong with running a truck without any pipes? got my truck running but i don't have an exhaust for it right now and want to take it around the block to make sure everything is running right. could i damage anything? neighbor said i could burn the valves but i don't see how snapping an exhaust on would stop that
Neren is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 12:40 PM   #2 (permalink)
Member # 74903
He is correct, because with the exhaust on there is a certain amount of back pressure that is applied to the engine.....exhaust isnt just for noise...also depending on the year it isnt going to run right because you will not have your O2 sensor hooked up....
tikitgvr is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 12:43 PM   #3 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
we did this on a 89 amigo 2.6L, we just put a new frame under it and new block, fired it up with only the manifold and a 12" pipe on it, ran it maybe 5 miutes with no problems just to make sure it ran right, but from what im told if you dont run a pip or manifold youll warp the heads or something
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 01:06 PM   #4 (permalink)
Member # 47246
Send a message via AIM to NHRedneck
ive been running my truck around the yard for a month or 2 and its got holy headers and no exhaust...... if the motor is bone stock i wouldnt reccomend running it for very long without a muffler for back pressure... I wouldnt ever run a motor without a set of headers on it though..... it would be one hell of a flame show and that def isnt good for the valves....... if the motor has some work i wouldnt worry about it too much....
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 :
Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 :
NHRedneck is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 01:42 PM   #5 (permalink)
tennessee rockhumper's Avatar
Member # 52201
if you are running zero exhaust, on manifold, header, exhaus ect...
the lack of back pressure wont ruin the engine. the cold air that hits the valves when you turn it off will warp the shit out of things.
tennessee rockhumper is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 02:19 PM   #6 (permalink)
Member # 47826
X2 warped valves. if you run it... it gets warm... then the cold air gets in the exhaust ports and the material (valves) warps.
Thean Bellocchi
crusty1007 is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 02:48 PM   #7 (permalink)
Member # 70402
What kind of vehicle is this? Also what exactly do you mean by no exhaust? I think these are neccesary questions before you can get some good advice on it.
nooblet is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 06:22 PM   #8 (permalink)
Member # 76389
truck is a 1985 toyota with an 81 engine. i have ran it for about 3 mins altogether combined from turning it on about 4 times or so
Old 09-08-2006, 06:37 AM   #9 (permalink)
Member # 73059
You know I'v heard that all my life, But what about racing engines that only have short zoomes or header onlys???????
Rockhales is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 07:22 AM   #10 (permalink)
Member # 36399
they are holding in enough heat where cold air doesnt directly hit the valves etc.
And again exhaust has nothing to do with back pressure. Back pressure is evil..you really dont want it.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 06:31 PM   #11 (permalink)
Member # 24992
Now that makes some sense. I've heard people say you couldn't do it because of not having any backpressure, but I could never really see how that could possibly hurt anything. Burning valves never made sense either because how could it possibly be hotter without exhaust then with. Cold air hitting the valves and cooling them too quickly and making them warp makes alot more sense. Even just having a manifold attached would hold enough heat and trap the hot air keeping things from cooling off right away.
5.9 ZJ on 31's - Wife's DD.
'94 YJ - RE 4.5XD, 1" BL, Waggy 44's, 4.88's, ARB's & 35's.
SteveZ59 is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 07:28 PM   #12 (permalink)
KiGrind's Avatar
Member # 66647
Yeah well "Compression" horsecrap, there are enough vehicles on the road with 3" of worthless pipe running out to a flowmaster 40 and a crome tip with "TRUE DUEL" that never connects that prove you don't need it.
70 Jeepster Commando
95 ZJ
KiGrind is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 10:09 PM   #13 (permalink)
Member # 67882
He did this to a olds. just load and allmost burned all the wires but besides that no harm
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 09-01-2013, 03:40 PM   #14 (permalink)
Member # 335050
its not back pressure its exhaust velocity the only danger is running without exhaust is on the intake stroke the exhaust valve may not be fully closed bringing in cold outside air warping or cracking a valve.
81jeepmutt is offline   Reply With Quote Quick reply to this message
Old 09-01-2013, 06:41 PM   #15 (permalink)
Provience's Avatar
Member # 138976
Correct, but hopefully after 6 years he isn't still running it without exhaust!
Backpressure is required on a 2 stroke, not a 4...hence why smooth exhaust bends and polished ports are good on the exhaust side.
I just want to build cars, collect watches and get tattoos.
Old 09-03-2013, 11:05 AM   #16 (permalink)
Member # 356162
You need about 12" - 15" of pipe coming off of the headers on a stock or mild engine so that you don't suck cold air in and warp a valve. Also, yes, backpressure is evil on a 4 stroke.
The mind is the most powerful weapon.
CledusVanDamme is offline   Reply With Quote Quick reply to this message
