Member # 29812
Mis-alighnment spacers ?????
I want to get some 1" heims, with mis alighn spacers for my radius arms
Do all of the spacers (for the same size heim) provide the same amount of mis-alighnment? Or do you get more angle the smaller the bolt size? Heims allow about 22.5*?? About how much do the spacers add to this? Thanks Joe
1984 Bronco, becoming BUGGY 351W/NP435/NP203/NP205 -WANTED- 460!!!! D60 / 10.25 W/4.88s TRACK LOKS 37" SSR 1954 WILLY'S CJ3B 350/NV435/D300 D30/D44 4.27s 33 BFG |
My understanding is the mis-alignment spacers allow you to get that full 22.5* of movement. If you install the heim with a tab on either side you would be limited on your movement since more than likely the heim would hit the tab before using up its full travel.
97 TJ - 5.13's, 9" Detroit, HP44 ARB, 36" TSL's 06 F350 - Towing Duties |
Member # 29812
So what if you used, a couple pices of thiner walled tubing the same diameter as the bolt.
Not as good as a mis-spacer, but would work better than just clamping the hiem right?
I don't see why that shouldn't work, provided you can find a piece of tubing with the correct dimensions and without it costing much more than just ordering misalignment spacers.
Member # 29812
But "high" mis-align. spacers that go to a smaller bolt diameter. do they give more angle deflection?
I have a set of james duff arms, with a 1" heim on one end, and my susp will flex and tigten (or loosen) the ends because they don't allow enough flex.
Member # 74903
you have regular mis alignment spacers and HI misalignment...the regular keep the same size bolt and give you a little more misalignment, the hi misalignments step down one bolt size and give you more misalignment...
Member # 22176
Call the guys at PolyPerformance. Tell them what you are trying to do and they can tell you how much misalignment you will get either way.
I can break a steel ball in a rubber room! |
