2" IFS lift questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-14-2006, 12:13 PM   #1 (permalink)
Member # 79297
I have a 90% stock 87 4runner. Looking at lifting it 2" by installing a SAW torsion bar and cranking it up a little. I would also like to put 33s on it.
Rear end will probably be an add-leaf w/ shock or high arch leaf.
My question is, is there anything I have to do with the rest of the truck to make this possible ie. gear ratio, driveline, stearing coloum.
Please keep in mind, this is not an xtreme off road vehicle. It is mostly for playing in the mud and medium trails.
Any other ideas would greatly be appreciated.
klap is offline   Reply With Quote
Old 09-14-2006, 02:36 PM   #2 (permalink)
Mud Dragon's Avatar
Member # 67479
I put a 3 inch bodie lift on my 88 4 runner and put 33's. I had to crank the front just a little and looks good and only cost me 89.00 for the blocks from summit. Yook me about 4 hours to put it on bye my self. I do about the same wheeling and I have not had any problems. I don't think 2 inches will cut it for wheel to clear the front fenders..Good luck
Mud Dragon is offline   Reply With Quote
Old 09-14-2006, 04:01 PM   #3 (permalink)
Member # 18006
This stealthy IFS in our club has a 1" body lift and slightly cranked t-bars to clear 33's.
Stealthy
President
Gettin' Off 4X4 Club
'89 XCab - Dual Marlin w/4.70 in rear case, D60 Hybrid SAS, locked, FJ80 HP front, .......
'97 TJ - Atlas 3.8 TC, ARB's F&R, ......
Terry4X4 is offline   Reply With Quote
Old 09-17-2006, 03:20 AM   #4 (permalink)
Member # 79297
Thanks for the responses.
I am guessing since no one mentioned it, with a 3" lift and 33" tires, the truck as stock could take it...ie. gear ration, stearing box...etc.
Old 09-17-2006, 04:55 AM   #5 (permalink)
Member # 64023
I drove a 88 with 32's and it was a dog even with the v6 to get up to speed down the highway. I would lift it, put the tires on it, drive it, and see what else you need to do.
92 GMC 1500 SAS, 383 475hp/450tq, FAST injection, 37" Toyo MT
clemet is offline   Reply With Quote
Old 09-17-2006, 08:56 AM   #6 (permalink)
hotshoe's Avatar
Member # 23307
Check out 4 Crawlers site for this appiication. I would recomend the ball joint spacers vs the torsion bars, much much better ride and you will get some flex. The cranked t bars will knock the fillings out of your teeth.
I run a 1 inch body lift, ball joint spacers, and some Chevy rear springs and I clear 35's with some trimming.
I am the Toe Cutter, have you seen the Night Rider?
97 T100 Under the knife
hotshoe is offline   Reply With Quote
Old 09-17-2006, 09:25 AM   #7 (permalink)
Grim Reaper's Avatar
Member # 6726
No lift, No torsion bar crank. 33x12.5x15 BFG KO's on stock offset 15x7 rims. Truck is totally stock otherwise except for an extra leaf in the rear to take care of a sag problem. Just hammered the pinch weld flat to the body mount and the inner lip of the fender next to it and trimmed the plastic liner. The key is the wheel offset.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is offline   Reply With Quote
