Swapping the Yoke on a D44 - pull the gears or can I just retorque the new yoke on? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2006, 11:24 AM   #1 (permalink)
Member # 18540
Send a message via AIM to YJ_OVER_SJ
on the trail a few weeks ago I had some serious axle-wrap take out a rear ujoint. While it took out the ujoint, it also wiped out the little ears on the yoke that keep the ujoint centered. I have a swap for the ujoint but not sure if I can swap it out in my garage(pull driveshaft, pull old yoke, put on new yoke, torque properly to set) or if I'll have to have the axles/gearset pulled to get this done.
If I can just swap the yokes, what's the torque setting?
Thanks,
Mike
"OBie"
CalRocs 2010 #5150
YJ_OVER_SJ is offline   Reply With Quote Quick reply to this message
Old 09-20-2006, 11:28 AM   #2 (permalink)
Wilson's Avatar
Member # 7233
You can just swap them. I'm not sure on the actual torque spec, but I go somewhere around 90 ft lbs. The shims will keep the yoke from bottoming the bearing, can't really do any harm by going tight.
Wilson is online now   Reply With Quote Quick reply to this message
Old 09-20-2006, 12:04 PM   #3 (permalink)
Member # 18540
Just to confirm, does a D44 use shims for setting pinion preload or does it use a crush sleeve(since I didn't specify above but you replied stating shims). If it uses shims, that'll make things much easier.
Thanks for the response Wilson.
"OBie"
CalRocs 2010 #5150
Old 09-21-2006, 07:13 PM   #4 (permalink)
Wilson's Avatar
Member # 7233
Shims, I knew what you were getting at, which I was saying not to worry about it
