Convert from 5 bolt to 6 bolt pattern. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2006, 11:03 AM   #1 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Send a message via AIM to lttlbddy Send a message via Yahoo to lttlbddy
This is a D44 from an F250. Can I just swap in some Chevy parts to get to the 6 bolt wheel pattern?
Thanks!
lttlbddy is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 11:07 AM   #2 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
yes
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 11:53 AM   #3 (permalink)
Member # 6867
Yes....
I'll ASSUME you're talking about the spindle mounting pattern...not the wheel mounting pattern. Cause we all know an F-250 would be 8 lug
Use all GM and you'll need the stub axle too...from the ball joints out, get the whole thing.
Eric
urjb is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 03:25 PM   #4 (permalink)
Member # 73066
you are better off just swapping the whole axle. you can score a six lug front axle cheaper than peicing all the parts you are going to need to do the swap. another cheaper alternative is to call moser axles and have them redrill your current rotors for a six lug pattern.
bbwag is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 04:44 PM   #5 (permalink)
Member # 66555
Send a message via AIM to GAredClaYJ
I've got a set of chevy knuckles, from ball joints out. They are six lug. If you're interested, PM me.
Jordan
GAredClaYJ is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 09:07 PM   #6 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
We'll I don't know about that. This has been narrowed and is in my EB. It already has Moser axles and CTM joints. I am going to be building the rear 9" next and am considering changing everything to 6 lug to match my other 2 trucks.
If feasible.
Old 09-26-2006, 09:10 PM   #7 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
See, this doesn't sound to unreasonable. Or replace the rotors with 6 lug if the innards will fit.
Old 09-26-2006, 09:22 PM   #8 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Maybe I mis-spoke about the F250. It is '79 HP 44, narrowed for EB, running F150 tie rod and drag link also narrow to EB, F150 hubs and rotors with t-bird calipers.
I knew you guys would keep me honest
Okay, so now what do you think about converting to 6 lug pattern? It is just so I will have swapability between vehicles.
I'm getting ready to buy wheels and tires, so I need to figure it out before I built the 9".
Thanks again for the responses.
Old 09-26-2006, 09:42 PM   #9 (permalink)
Member # 25325
Send a message via AIM to redranger4.0
i think its more work to convert both axles then needed. what rims and tires would you be swaping and why?
redranger4.0 is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 10:02 PM   #10 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
If it is too much work and money, it probably won't happen.
The 9" is getting upgraded to probably 31 spline (I don't know if I can justif 35 spline, only planning on 37" tires), maybe FF, just thought about 6 lug.
I already keep a couple of 6 lug spares for my other truck. My 1/2 ton truck is Chevy 6 lug, so I just thought, why not keep 6 lug for everything.
Not a real big deal either way but if it is easy and not to much $$, I rather have 6 lug wheels all around.
This is info gathering.
Old 09-27-2006, 07:37 AM   #11 (permalink)
Member # 6867
Its gonna depend on the knuckle application then...
If you have the 5 bolt spindle from a later F150, I dont think the GM hub and rotor will work...the bearing sizes are right for the early GM hub, but the offset is wrong.
If you have an older 6 hole spindle, then you keep the knuckle and use an early GM spindle and hub and stub and caliper brkt.
Worst case is still ball joints out with all GM stuff. not really all that bad. you are gonna toss alot of your existing stuff tho. rework steering and probly tinker with the brakes too.
Eric
Old 09-27-2006, 08:31 AM   #12 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
I'll have to park it next to a Chevy D44 and swap some parts to see what is what.
Thanks for the opinions.
