Start up squeal... can't figure it out - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-30-2006, 04:40 PM   #1 (permalink)
Member # 62796
I've got an 89 Toyota 3.0 six cylinder. Everytime I start it when it's cold, it squeals. I've changed belts, tightened belts, used belt dressing. It still squeals. I can rev it up, and it will quit, then it wont do it until I shut it off and then start it again. Any ideas on what to do? It's starting to aggrivate me.
SDJeeper99 is offline   Reply With Quote
Old 10-30-2006, 05:28 PM   #2 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
does it only do it when its cold or can it be warm and you shut it off and start back up it squeals? sounds like it could be a bearing, if its not the belts being too tight.
Only in a Jeep
Murfman is offline   Reply With Quote
Old 10-30-2006, 05:40 PM   #3 (permalink)
Gives Zero
red90runner's Avatar
Member # 35527
Send a message via AIM to red90runner
I have a similar problem on my 1999 4runner with the 3.4L. Haven't checked it out yet, but my guess it was a belt or something. I am interested to see what ur problem is if its not the belt.
-Pat
Polygoats Offroad Club
red90runner is offline   Reply With Quote
Old 10-30-2006, 06:12 PM   #4 (permalink)
Member # 51594
If its not a belt, then it might possibly be a bearing in the water pump or alternator.
BlazerGuy 90 is offline   Reply With Quote
Old 10-30-2006, 06:34 PM   #5 (permalink)
Member # 62796
It very seldomly squeals a bit when it's warm. I just had a thought though. My AC compressor is siezed.... wonder why I didnt think about that earlier.
Old 11-01-2006, 09:59 AM   #6 (permalink)
Member # 25807
Check the tensioner bearing.
00 TJ 4.0 Auto 4 Speed Atlas ProRock 60s 5,38 ARB 46" tires 104" WB
stannuri is offline   Reply With Quote
Old 11-01-2006, 10:32 AM   #7 (permalink)
Member # 71580
A belt squeal is almost unmistakeable. IS there a tensioner bearing in the ac compressor ? You say your ac compressor is SEIZED. Does the pulley spin ? If you could get someone to start it for you then you could stand infront , mark with a white marker , and see if it doesn't spin for the "start up" , which would be why it's squealing. Also if that is the case. I think the intervals you're supposed to change your belts at are so short that you would be okay with that squeal for a couple extra weeks if you can't afford that AC compressor. You're not going to use that Ac compressor this winter so that could wait. Can you get the Compressor REPAIRED ? Also make sure you have the right TYPE of belt for the pulleys you have. You know..... VBelt, V RIBBED ! belt .............
Adam3000 is offline   Reply With Quote
Old 11-01-2006, 01:02 PM   #8 (permalink)
Member # 35837
A buddy of mine has a cherokee that does the same thing. We replaced belt, alternator, and pulleys. Still haven't figured it out yet usually just rev it up a couple times and it quits. I guess we will just deal with it.
yotaboyz is offline   Reply With Quote
Old 11-02-2006, 06:04 AM   #9 (permalink)
Member # 71580
Does YOUR friend have an ac compressor ?
Old 11-02-2006, 08:41 AM   #10 (permalink)
Member # 35837
no!
Old 11-02-2006, 08:57 AM   #11 (permalink)
4in100's Avatar
Member # 51267
Send a message via AIM to 4in100
check the tensioners and pulley bolts. I had a squeal that turned out to be the harmonic balancer wobbling because the crank bolt head broke off....grrr
4in100 is offline   Reply With Quote
Old 11-02-2006, 10:21 AM   #12 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
i have something simmilar in my 1990 dodge spirit, cold starts it screams like a lil pig, when i turn on the heater at idle it screams, mine is my alt bearings i think, id take the bulley off the alt and turn it by hand, listen for bad bearings
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
Old 11-02-2006, 10:35 AM   #13 (permalink)
Member # 71580
Originally Posted by yotaboyz
no!
Oh I see.
Old 11-02-2006, 06:08 PM   #14 (permalink)
Member # 42069
I dont know how it compares, but our snow cats at work, when the fan clutch starts to go, sometimes they will squeal real bad on cold start up, sounds just like a belt squeal. never heard a car fan clutch do it, but i guess if a larger fan clutch can, maybe a car one could too?
I tried that jeep thing....but I still don't understand it!
Hillbilly_jeeper is offline   Reply With Quote
Old 11-03-2006, 05:42 AM   #15 (permalink)
cheaprides's Avatar
Member # 40933
Send a message via AIM to cheaprides Send a message via Yahoo to cheaprides
take the belt off and start the truck cold. see if you can get it to make any kinda noise. no noise so turn each pully to see if anything feels "scratchy" bearings are going outa something this is the easyest way to tell
84 toyota on junkyard 31s and dual cases. still building
cheaprides is offline   Reply With Quote
Old 11-03-2006, 06:42 AM   #16 (permalink)
Member # 71580
I didn't know that...............
