I have been working on this specific problem for about 2 weeks now in my 4 hours before work and have hit a stand still. Probably can't see for looking. I have a 85 xtra cab toyota. I had a 85 regularcab that the frame rotted on. I have swapped the motor, harness, computer from reg cab truck to xtra. Was running fine. swapped over springs, front and rear end. Truck was running fine.
I took the cab and front clip apart and painted then reassembled. Again truck ran.
I removed the seats and herculined the interior of the cab. While the seats were out I installed a volt meter and manual temp gague where the radio used to be. I connected the voltmeter and gauge lights to the light fuse and grounded out on the drivers side kick pannel with other grounds. After putting the seats back in the truck WILL NOT CRANK!
The motor spins fine but is not getting fuel. I pulled a code 11 which is ecu or TPS. Fuel pump runs when key is turned. Have fuel at cold start injector. Used a test light at cold start injector and had spark. Have spark on all 4 spark plugs?
I then removed the gauges and returned all wiring to the way it was. Reset ecu and still code 11. tried another ecu, still 11. Ran new grounds batt -motor, batt-fender, fender -motor, firewall-motor. The ground to intake is cleaned and fine. I hear the relay on drivers kick pannel click when key is turned. all fuses and fuseable links I see are fine. I jumped the efi relay this morning and blew the ign fuse. I don't know what that means if anything. I am stumped. I have fuel fire air. I think I have just looked at it too much and can't see anymore. Any way thought I would ask here as I have found so much helpful info in the searches. Thanks
-Will
-Will
