I`m about to set up 2.5" 16" fox air shocks up front and 2.0" 18" Race runners in the rear.and I`m not to sure about how the internal bump stops work.
If i set up the shocks with 5" of shaft showing am i going to get 5" of up travel?
Do I still need external bump stops?
I think I`ve read to much or not enough on the right info
Just to double check how to set up:
Remove the valve and fully compress the shock
Completly fill the shock with the weight of oil chosen
reinstall the valve
bolt up to the rig and get full axle drop and charge with nitro to about 130psi
drop the rig back down shake it around abit and check ride hight
and if its all good your done?
reinstall the valve
