Just did a saginaw power steering conversion on pops cj5. Standard used saginaw 800 box I believe. When I fired it up to bleed the system the top of the box is leaking from under the four bolt cap that has the adjuster shaft through it. Tightened the four bolts on top which slowed down the leak but did not stop it. Pulled the cap off and there is no gasket. Should there be one on it? Any ideas as to why it leaks and solutions to make it stop? I will eventually have the box rebuilt but I would like to get it working for now as I want it out of my shop. Any ideas are appreciated.
