Member # 10063
Take it easy on it, and it'll probably hold. The weak spot on those is the neckdown on the shafts just inside the diff.
An actual locker of some sort would greatly reduce the strain on it though (not to mention, you'll actually be able to STEER the thing, too).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
#6 (permalink) | |
Member # 36399
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks 95 F-150 6" of lift, SAS 35" BFG's |
Its being pushed by a semi-smogged 2bbl 351 with 120K on the clock, and a 435-208. There is not a lot of all out rock wheeling to be done out here. Mostly Trails of varying terrain I would put it in the 80% risk of Body damage 'mild' catergory.
nothing but a bunch of pipe and cast off parts. |
Member # 17313
In my expirance, they seem to hold up pretty well.
We have a club member that wheels(and DD's) a 94' F-250, with a 351 in it, that I welded the diff up in a last year. Right away it broke the inner shaft, harsh break, at a 45* angle. that was running 35" geolanders. However, this year he has wheeled it HARD, with 35" boggers on it, and nothing has broke yet.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
I assume you mean the 38*11 or whatever boggers? Im gonna say you may be ok. I put a locker in my old D44TTB and immediately (5 minutes into the trail) exploded the center ujoint (which was new), but the D50 has a bigger ujoints so it might be ok. Was running 36" iroks at the time. Go easy on it, definitely dont jump it, and you should be ok. Definitely check that center ujoint after a wheelin trip. Maybe even tack weld the caps in palce so they cant spit out.
I wouldnt buy a locker for it, id save up and spend that cash on a D60 instead.
88 bronco // 96 F250 // 91 zuk |
