I was given a 9 inch, well pieces of a 9'' and I dont know what vehicle it came out of, I think the guy said it was a 70 something F150 but I cant remeber. So I grabbed as much info on it as I could since I didnt find a bomb number or and ID tag to get a reference from. So what I do know is it is 60 inches from backing plate mount to backing plate mount ( see first pic) and the leaf spring purches are 42 inches from ech other ( inside ot inside measurement) it had 28 spline shafts. The third member casting had these numbers C7AW 4025e 19. It had 42-10 gears and I belive the bolts for the backing plate are 7/16s and are 1 1/2 inches long.
The main questions that i had are:
-I am planning on doing a 35 spline spooled rear, no will i be able to run the 35 spline shafts without boring out the axle tubes.
-is this a big bearing or small bearing housing/axles? thanks for any help.
