Hello all!
On Saturday I purchased a 2006 Dodge RAM 3500 4X4 from a local dealer new. The dealer had a 4X4 shop add some aftermarket stuff to the truck and one of these items was a 5” lift kit. I wanted to ask you guys what you thought of the kit and if I should add anything else. I am just worried they went as cheap as possible and did not add everything needed. I contacted the performance shop and they sent me the below email.
-----The lift kit is made by Fab Tech, and the part numbers are: FTS23006BK, FTS7237, FTS7333, FTS43000BK. The only maintenance required is to grease the grease fittings. The work we do for the dealership is 3 years/36,000 miles.-----
When I look on Jegs website I found these part numbers with the below descriptions, but there is no detail. I think the last three are pretty easy to figure out, but I am not sure about the first one.
DODGE 4WD 2500 BOX KIT - 391-FTS23006BK
DDGE 4WD 2500 COIL - 391-FTS43000BK
PERFORMANCE SHOCK - 391-FTS7237
PERFORMANCE SHOCK - 391-FTS7333
Any help would be greatly appreciated.
