9" minispool install - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-08-2007, 07:14 PM   #1 (permalink)
Banned
Member # 68805
I won an auction for a $20 new minispool on ebay, and I'm looking to install it in a 4.10 3rd I'm getting for free in trade with a friend who only needs a bare case...and I just found out today that I'd need to split the carrier to swap out the spiders for the spool...I'm alright with setting backlash again and whatnot, but I can't for the life of me find out how to take the carrier apart.
Here's an open carrier that came out of the 9" case I'm trading to him...I see the pins but those aren't screws holding the pins in place....they look like dowels or just round tube.
Excuse the noobness, I'm used to Dana carriers with the open holes in the sides.
TJVigilante is offline   Reply With Quote
Old 05-08-2007, 09:20 PM   #2 (permalink)
Member # 66555
Send a message via AIM to GAredClaYJ
If you're just putting the minispool in your current member, you should not have to adjust your backlash or make any other adjustments. The pins you mention are roll pins. Take a punch or drift that has a smaller diameter and punch it out. This will free up the cross pin and you can then replace your spider gears with your mini. Replace the cross pin, put the roll pin back in it, and the reassemble your member...good to go.
Jordan
GAredClaYJ is offline   Reply With Quote
Old 05-08-2007, 10:12 PM   #3 (permalink)
Banned
Member # 68805
See the thing is I need to remove the carrier from the 3rd to install the minispool in the 9", and it's got this wierd threaded thing instead of shims that set backlash, so I need to re-check it after I set it back in the 3rd.
Even if I remove the roll pins, I can't get the spool inside the carrier...the hole you see is the only opening into the innards. The pins are also covered by the ring gear when installed.
Old 05-09-2007, 02:00 AM   #4 (permalink)
Banned
Member # 68805
Maybe someone can move this into the Ford section so I can get an answer?
Old 05-09-2007, 04:17 AM   #5 (permalink)
Member # 66555
After removing the ring gear, the case splits in half. Once you remove the roll pins, then the cross pins come out and you can remove the spiders. Reverse all of this to install the mini. I don't see exactly what you're stuck on.
Old 05-09-2007, 10:03 AM   #6 (permalink)
Banned
Member # 68805
I'm stuck on the case splitting in half. Although, I now see where it happens...so I'll give it a shot later today.
Thanks for the reply.
Old 05-09-2007, 02:10 PM   #7 (permalink)
Banned
Member # 68805
I should have just gotten a full spool....I'll have to set backlash again anyway. Grr. Oh well, this is cheaper.
Old 05-09-2007, 11:21 PM   #8 (permalink)
Banned
Member # 68805
Well I gave it a shot today, for a little bit before my neighbor came out in a huff because I was pounding on the diff at 10pm. That thing wasn't budging...maybe tomorrow I'll give it a little more elbow grease and break it free.
The 4.10's I got for free seem to have a traction lock diff....it's got the recessed ring gear bolt seats and more than one hole in the carrier, but looking inside it doesn't show anything different from the open carrier in the picture. Am I supposed to notice clutch disks or anything through those holes?
Old 05-16-2007, 08:13 PM   #9 (permalink)
Member # 17313
you have to remove the ring gear bolts to get the carrier split in half..
But anyways, put the mini back on ebay, and get a full spool, otherwise you will be doing it all over again when the cross pin breaks.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 05-16-2007, 10:04 PM   #10 (permalink)
Banned
Member # 68805
I'm thinking of just going with a full spool...
And I already removed the ring gear bolts...can't you see the picture?
Old 05-17-2007, 07:37 PM   #11 (permalink)
Member # 17313
I can see the pic now, did you add it after I posted? or maybe it wasn't working.. either way.
Just split the case with a chisel.. or better yet, put in a full spool.
Old 05-18-2007, 01:38 AM   #12 (permalink)
Banned
Member # 68805
Actually it was there, but the link seemed to be bad. I edited it with another URL but it looked to be the same.
I'll run out and get a chisel tomorrow and see if it works.
