Ford 8.8 shaft/ c clip removal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2007, 05:17 PM   #1 (permalink)
Member # 82861
i am trying to remove my axle shafts, and cannot figure how to get the c clips out and the pinion retaining bolt. thanks in advance, sam
2002 Jeep TJ, Ford 8.8, Clayton Rear suspension, 4" stretch, Build-up Coming Soon
smurison14 is offline   Reply With Quote Quick reply to this message
Old 08-12-2007, 06:32 PM   #2 (permalink)
hitech_hick's Avatar
Member # 62866
What kind of differential do you have? It has been a little while since I have messed with a stock carrier. You need to remove the cross pin first,then need to push the axle shafts inward until you remove the c-clips that retain the axle shafts.
hick
'97 XJ, D30, Ford 8.8, 35's
'94 Mazda B4000, D35 TTB, Ford 8.8, 35's
hitech_hick is offline   Reply With Quote Quick reply to this message
Old 08-12-2007, 06:39 PM   #3 (permalink)
Member # 82861
hick
it has the stock LSD in it, is the cross pin in the middle of the differential? How do you remove it?
Old 08-12-2007, 08:32 PM   #4 (permalink)
Member # 68697
There should be a small balt (like 7mm or something). Remove it. When you remove it you should be able to get that cross pin out. After it's out, you can push in the axale shaft to get some slack to get the c-clip out. A magnet helps here to grab the c-clip.
Mike
mingoglia is offline   Reply With Quote Quick reply to this message
Old 08-12-2007, 09:06 PM   #5 (permalink)
Member # 82861
i may be a tard, but i do not see anything in the carrier that i could get a socket on
Old 08-12-2007, 09:12 PM   #6 (permalink)
Member # 62866
Have you rotated the differential all of the way around? The bolt is fairly small...
hick
Old 08-12-2007, 09:32 PM   #7 (permalink)
Member # 82861
okay, i think i have found it. It is on the top side of the diff, isnt it? i will post up tomorrow if it works.
Old 08-14-2007, 07:18 PM   #8 (permalink)
ProjectGoat's Avatar
Member # 96193
As mentioned above, with the 8.8 you have a very small bolt that holds in the cross pin that prevnts the axles from pushing in any further. You remove this bolt, should be 5/16". Once removed, knock the pin out, you will probaly have to rotate the diff some to get it too come out. Once the pin is removed, push in the axle, when it does, take some needle nose plies, and remove the CClip, then pull the axle out. Repeat for the other side. Sometimes, the CClip will fall out without the need for needlenose pliers.
[FONT="Arial Black"][SIZE="2"][COLOR="Silver"]ProjectGoat: '03 QC DRW NV5600 Cummins 508HP/1008TQ 2WD being converted to 4WD[/COLOR][/SIZE][/FONT]
[FONT="Palatino Linotype"][SIZE="4"][COLOR="RoyalBlue"]"Hell hath no fury like a Pirate member insulted"[/COLOR][/SIZE][/FONT]
[FONT="Garamond"][SIZE="5"][COLOR="Red"]God Speed Jason: My Truck+Mogs=Build Time[/COLOR][/SIZE][/FONT]
ProjectGoat is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 10:43 AM   #9 (permalink)
Member # 62866
Small magnetic wands work well for this as well.
hick
Old 08-15-2007, 11:17 AM   #10 (permalink)
Member # 82861
i have to go out and find a ratchet that will fit in the small space between the housing and the carrier.
Old 08-15-2007, 12:14 PM   #11 (permalink)
Member # 96193
hick
Old 08-15-2007, 12:14 PM   #12 (permalink)
Member # 96193
Box end wrench
Old 08-19-2007, 02:02 AM   #13 (permalink)
Member # 85316
Send a message via AIM to svt150j49
its an 8mm wrench. and dont shear the bolt. or you are going to have one hell of a time getting it out.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 03:24 PM   #14 (permalink)
Member # 82861
pulled the shafts out today, thanks for the help. Those wrenches do help, dont they!
