help me decide which chevy??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-23-2007, 08:25 AM   #1 (permalink)
Member # 101375
ok, i am in the market for a classic chevy 1 ton 4x4 pickup. it will be a daily driver as well as my offroad rig as well as something i plan on driving to panama and back. At some point it will have a diesel and a manual trans.so i am running into a few questions.
1. what is the difference other than axles between 1/2, 3/4, 1 ton models
2. what should i look for in a old chevy. ie:frame rust, certain model years, tc, etc.
3. and probably the most important where are they....? everyone says parts are everywhere so i assume that also means trucks are everywhere, but i can't seem to find any and when i do they aren't 1 tons..any ideas?
generally any tips you guys have for me i'll be happy to take.
ncjeepin is offline   Reply With Quote
Old 11-23-2007, 03:20 PM   #2 (permalink)
Member # 80727
1 ton = th400 trans or heavy duty version of the sm465 and a 205 tcase.
Has a dana 60 front axle and 14b full floating rear. Pre 79's I believe had dana 60 or 70 rears. 8 lug axles.
3/4 ton = th350/700r4 , rarely th400 trannies or the light duty aluminium sm465, 208 case sometimes 205 (dont hold me to that).
Has a dana 44 front (pre 79) or 10bolt and 14b or d60 (pre 79). 8 lug
1/2 ton = Only weight rating made short/stepside bed. 700r4 sometimes th350, light duty sm465 for a stick. 208 case.
Has dana 44 front (pre 79) 10bolt post, 12bolt rear (pre 79) 10bolt post. 6lugs
For simplicity if you anticipate having to do a stick swap the best bang for your buck would be a CUCV truck. Its a 6.2 diesel which while they are a dog its still diesel torque. Those trucks are all 1tons with a th400 automatic. They come with 4.56's and a locker in the rear stock. Definatly a good deal. Drop an sm465 behind it and put your lift and tires and your good to go.
If your looking for a woods truck there is the options of running a shortbed and swapping all the running gear out to a 1ton truck's. Some people dont like the long wheel base and doing 3 point turns where the jeep guys just go without problems.
Some people like me
1994 Isuzu Trooper: OM617/W56/toybox
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is online now   Reply With Quote
Old 11-23-2007, 04:40 PM   #3 (permalink)
Member # 101375
oh ok, i thought there may be differences in the frame thickness or something. well the front runner is a cucv actually. will a sm465 need an adapter? forgive my ignorance. another stupid question is: isn't sm465 a 2wd tranny? does it need anything extra for 4wd?
thanks
Old 11-23-2007, 04:48 PM   #4 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
The frames are thicker on the 1 tons. Also 73-81s have thicker frames than 81-87, GM changed the frames and made them lighter for fuel economy on the 81 and newer. The SM465 was used in 2 and 4 wheel drives. I used a shortbed frame and swapped over all 1 ton parts. I like the shortbeds better the 8 foots have a very wide turning radius.
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 11-23-2007, 05:13 PM   #5 (permalink)
Member # 101375
so what would i be looking for between 73-81 that has a 60/14b combo? i think it may be better to just buy a classic truck, diesel, sm465, cucv axles. how much can i expect to pay for a old pickup? actually kinda broad question but, hey. basically i got $3500 (for now)so what do you guys think i should do.
with my needs a longbed has more advantages then disadvantages. i may however chop the end a bit but it depends..i figure i can get a 91+ 6.2 and sm465/205 $1000 60/14b $1000(too much??) that leaves me with atleast $1500 for a truck????ideas
Old 11-23-2007, 05:58 PM   #6 (permalink)
Member # 68512
Some people like me
wrong.
first off, the 14b was used from 73' on in both 1 ton and 3/4 ton. there may be a few d70's but no d60's after about 70'.
1 tons, 3/4 tons, and 1/2 tons can all come with a 205, 203, 208, and 241 transfer case.
and they also come with the same sm465, not matter what the GVWR is. the only difference would be the output shaft. 465/208 will have a 32 spline output shaft, and the 205/203 versions will have a 10 spline. they are all cast iron cases.
also, iirc, there wasnt a k30 (4wd 1 ton) before 77' when the d60 front was introduced.
89 s10, flogged regularly
94 burb, tow rig
Donahue is offline   Reply With Quote
Old 11-24-2007, 12:06 AM   #7 (permalink)
GMCTruxrule's Avatar
Member # 51243
Some people like me
Heavy duty version of the 465? I didn't know that there was a "light duty" version....
And there wasn't an "aluminum light duty version", I think you are thinking of the 465 trannies post 1980 that had aluminum case tops, its not light duty brother.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 11-24-2007, 08:02 AM   #8 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
boy, im glad i missed this one... almost sent me into a fit.
thank you for the corrections... my head hurts.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 11-24-2007, 08:16 AM   #9 (permalink)
Member # 83920
Wondering when you'd get here
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote
Old 11-24-2007, 08:25 AM   #10 (permalink)
Devout Newbie Hater
Member # 20147
lol, im still trying to get rid of the *twitch*.
Old 11-24-2007, 11:07 AM   #11 (permalink)
Member # 93774
Biuld One,Maby? I took a 83 Blazer, Bolted in one ton running gear, wa la, One ton Family Car/ Rock Crawler/ Wood Hauler(w/trailer). I do like the 10" shorter wheelbase of a blazer , But I guess It depends on what you want do do with it.
On the other hand I've always wanted a one ton early 70's pickup.
Jediwelder is offline   Reply With Quote
Old 11-24-2007, 05:48 PM   #12 (permalink)
Member # 17646
Check under vehicles for sale.Im selling a k30 asking $4250 obo
Go Big, Go Hard, or Go Home
Jetwrench is offline   Reply With Quote
Old 11-24-2007, 10:05 PM   #13 (permalink)
Member # 91791
Send a message via AIM to g-wizz
Some people like me
what is a light duty sm465?
g-wizz is offline   Reply With Quote
Old 11-24-2007, 10:08 PM   #14 (permalink)
Member # 91791
thanks
cucv should be good. adaptor for what? there are 2 and 4wheel drive versions of the 465
on a side note are there 4wheel versions of the sm420? and that is stronger than a 465? right?
Old 11-24-2007, 10:19 PM   #15 (permalink)
Member # 83920
There isn't a light and heavy duty SM465
Uhhh, no it isn't stronger.
SM420 = synchro-mesh transmission rated 420lbs/ft
SM465 = synchro-mesh transmission rated 465lbs/ft
Where do you guys get your information from?
Oh wait, let me guess. Other people on Parrot4X4 who don't know what the fuck they are talking about.
Old 11-24-2007, 10:23 PM   #16 (permalink)
Member # 91791
i dunno i read somewhere that they came in dumptrucks and stuff. what is stronger than a sm465
Old 11-24-2007, 10:33 PM   #17 (permalink)
Member # 83920
Oh, for fucks sake. you're throwing out bullshit information on 2 seperate posts about transmissions. One about Automatics, one about 4 speeds, and it is quite apparent that you have no fucking idea about either one, so why don't you shut the fuck up, read the posts, and try to learn something, rather than proving to the whole world what an idiot you are.
Old 11-24-2007, 10:57 PM   #18 (permalink)
Devout Newbie Hater
Member # 20147
lol.... busted........
now I remember why i didnt try to correct this thread.... too much shit wrong in the first place.
Old 11-24-2007, 11:05 PM   #19 (permalink)
Member # 51243
Comparing dump trucks and 465 transmissions for strength is like trying to compare Dell XPS laptops and mountain goats for intelligence.
Old 11-24-2007, 11:07 PM   #20 (permalink)
Devout Newbie Hater
Member # 20147
Originally Posted by GMCTruxrule View Post
Comparing dump trucks and 465 transmissions for strength is like trying to compare Dell XPS laptops and g-wizz for intelligence.
there, fixed it for ya
Old 11-25-2007, 06:47 AM   #21 (permalink)
Member # 101375
i'll go take a look
well i'm glad you guys didn't let me leave this thread believing that 2nd post...lol...well i'm really leaning towards a cucv/70's k-30,
Old 11-25-2007, 08:44 AM   #22 (permalink)
Devout Newbie Hater
Member # 20147
i'll go take a look
try for an 80 and later version. the early axleshafts on the dana 60 were necked down a bit. Most k30s had 4.10 gears, but there are some out there with 4.56s
either way, a k30 should have the np205, vs the cucv's NP208. not all cucvs had 205s...
Old 11-25-2007, 11:14 PM   #23 (permalink)
Member # 91791
well fuck man i didnt know i just heard. and the other tranney thread, i have a hd case and i was wondering if it is better than a k case but i guess they are both one and the same just different lettering cast into the case. i dont see to much wrong there. hade some dude tell me my case was a k case which it is not, maby a miscommunication about what i was asking but in that thread i was not claming anything so really i dont see how i was wrong. this one yes i was flat out wrong but hey i am learning and you still didnt answer my quiestion as to what is stronger than a sm465 or is that one of the strongest manuals chevy offered? there learn me something...
Old 11-25-2007, 11:18 PM   #24 (permalink)
Member # 91791
YOU DO NOTICE THE "right?" as in am i right or am i wrong fuck man so i made a mistake in my wording... should have gone like this....
are sm420s stronger than a sm465... you answer: the #= im guessing the max torq for the tranney so ya uhhh learned something new there.
