87 3/4 ton Mod ?'s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2007, 12:12 PM   #1 (permalink)
Matt_193's Avatar
Member # 103475
87 3/4 ton Mod ?'s
My Dad has a 87 3/4ton Chevy (Custom Dulex) with a 350. I was wondering what would be a good suspension lift for it to clear 33's. I know I'm only 14 and dreaming out loud but he said he would give it to me when I'm 16. I figured a 4in suspension lift would clear 33's. Would this be a decent daily driver if I invested some work into it. It runs good as of now but I just wondered if it would still run O.K with a lift.
So basicly what I'm asking is:
What size lift to clear 33's?
Who is a good company to buy from and what would it cost (Link Please)?
Would it work as a daily driver?
What would I need to do to make it work? (Trim Fender's general work)
My dad and I are Mechanical could we do it ourselves?
And one more where can I get body panels, or how do I fix Body Rust.
This is something like I would hope it to end up looking like
Matt_193 is offline   Reply With Quote
Old 11-25-2007, 12:41 PM   #2 (permalink)
Matt_193's Avatar
Member # 103475
Please tell me if I should move to the Newbie's Section. Thanks
Old 11-25-2007, 01:03 PM   #3 (permalink)
Member # 34044
14 huh.. there's alot to learn here if you take the time. it's well worth it.
a 4" lift will be plenty for 33's and 35's with a little trimming. for the back i'd get a shackle flip from www.diy4x.com or www.sky-manufacturing.com. that will give you 4" lift and keep your stock springs for a good ride and great flex. you will also need longer shocks and a longer brake line. for the front i'd get off the shelf 4" tuff country springs from 4 wheel parts or a store like that. again, you're going to need longer shocks and brake lines. new ubolts are a good idea. 4.10 gears would be nice too. good luck and have fun
'79 blazer on 4D's
srv8800 is offline   Reply With Quote
Old 11-25-2007, 01:26 PM   #4 (permalink)
Matt_193's Avatar
Member # 103475
Thanks for the info. I know I have to get new rear leaf spring's to since he put in new ones to handel some heavy ladder and tool box racks. So should I get some stock leaf spring's and then add the shackle flip? I figure brake lines will be easy to get.
Old 11-25-2007, 01:48 PM   #5 (permalink)
Member # 103068
Send a message via AIM to PerryM004
i'd move it too the newbie section, you might get flamed here
PerryM004 is offline   Reply With Quote
Old 11-25-2007, 01:51 PM   #6 (permalink)
Matt_193's Avatar
Member # 103475
Thanks, what is the best way to move it before anyone get's mad?
Old 11-25-2007, 02:41 PM   #7 (permalink)
Matt_193's Avatar
Member # 103475
Anyone know how to move or should I just make a whole new one over there?
Thanks
Old 11-26-2007, 05:06 PM   #8 (permalink)
Member # 34044
try to keep this kind of stuff to the newbie section from now on. did your pops swap out the whole leaf pack or just add a helper? if he just added a helper, you can take that out. the shackle flip will go on either way. 4 wheel parts wanted waaaaaaaay too much for brake lines. i got mine from off road design. chevy's are great at home projects for a first timer because there's a ton of bolt on's out there since everything is riveted together from the factory.
'79 blazer on 4D's
Old 11-26-2007, 05:43 PM   #9 (permalink)
Matt_193's Avatar
Member # 103475
Thanks, I pretty shure the whole leaf pack was swapped, but I'm not positive. I didn't know how to get it moved to the Newbies section, so I made a new thread there and then this one got moved afterward's so that didn't really work out but Oh Well. If you were interested I did go a little bit farther as far as suspension etc.
