Front U Joint? Combo? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-02-2007, 07:09 AM   #1 (permalink)
Member # 63982
i swapped my 10 n 12 bolt for a 12 and 14 bolt..(60 on the way though) anyways i had to get a combo rear joint but i read on coloradok5 that all front ujoints will be the same as long as the yoke hasnt been changed out... is this correct? so in theory a normal 12 3/4 or 1/2 ton front ujoint will work? thanks for the help boys
79 chevy-built sbc350/th350/np203/10B/14bFF- 6 inch,38in tsls.D60 on the way w. full hydro & doubler
pr0circuitkx is offline   Reply With Quote
Old 12-03-2007, 02:15 AM   #2 (permalink)
Member # 68512
ok first off you still have some reading to do.
there is no such thing as a 12 bolt front end. only rear, and afaik only 1/2 ton.
but to answer your question, almost all front ends are going to use a 1310 u-joint. but some later ones started using a 1330. really, the only way to know for sure what you need is to measure it.
a list of common u-joint measurements can be found on this page, about 2/3rds down.
http://www.pirate4x4.com/tech/billav...aft/index.html
89 s10, flogged regularly
94 burb, tow rig
Donahue is offline   Reply With Quote
Old 12-03-2007, 09:07 PM   #3 (permalink)
Member # 63982
ya ya ya no reading necessary... just my f up... 10 bolt. im sure you got the idea. thanks for the help
