Member # 47722
school me on tire load rating
search has not resulted in the answers I was looking for.
I understand what the load rating means in technical terms..but I'm looking for a little more specific type..yet more "laymans terms" analysis. I currently have worn down some E load rated MTR's. I'm not as concerned about on-road life and ride as I am about the likely hood of a bead breaking, and strength of sidewall while I'm scrubbing. Is it safe to assume that a C rated tire would be "more likely" to fail by breaking a bead than a E rated in identical situations??? From what I have read so far it would also "seem" that a C rated tire would bend/flex more than a E rated tire along it's sidewall in identical situations. Is this correct??? Thanks.
Professional Driver. Closed course. |
Member # 75473
you are correct. e load tires have more plys in sidewall than c load tires. their ability to carry more load is based solely on sidewall strength.
lead or follow, it doesn't matter. Just get the F@#$ out of my way! |
Member # 73191
Tire "ply ratings" or "load ratings" no longer actually identify a specific amount of plys the tire has but rather the equivalent strength compared to when it did correspond to the amount of plys. A load range E or "10 ply" tire does not neccesarily have more carcass plys than a load range C or "6 ply" but is stronger and can hold more air pressure and weight.
To answer your question, yes the higher load rating a tire has the stiffer it will be....but in instances of tire scrub and bead breaking the difference will is usually negligible in larger tires. |
