Parking / Emergency brake help NEEDED!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-07-2008, 02:03 AM   #1 (permalink)
Member # 105975
Send a message via Yahoo to 01_Offroad
Exclamation Parking / Emergency brake help NEEDED!!!
I've got a 2001 Dodge Ram 1500, D60 front axle, GM 14 bolt rear axle, with disk brakes. The 14 bolt didn't come with an e-brake, and I have to have to have one to pass vehicle inspections.
I've been searching on the site for the past hour.... Haven't found anything in regards to an e-brake kit that I can slap on what I've got. I've read about some Cadi calipers, that generally suck, so I'd rather avoid that.
Sounds like I need a driveline e-brake. I know NOTHING about driveline e-brakes, other than they're aparently my only option. I've seen the pinion brakes on Rockwells, but not for a 14 bolt. I've read about some on the tranny, some on the t-case etc.... I don't know where to start with my setup.
I don't care what it looks like, I just needs to work! I've got 13" of lift, and 41x14.50 tires, so it's got a bit to hold. ANY and ALL help is GREATLY appreciated!
01_Offroad is offline   Reply With Quote
Old 01-07-2008, 02:39 AM   #2 (permalink)
85jeepn's Avatar
Member # 63442
Send a message via AIM to 85jeepn
I don't know about your state, but most states won't except a drive line e-brake to pass an inspection. If the drive shaft brakes then you have nothing. They want them physically connected to the wheels. Just some food for thought.
Win at all cost. Second place is just the first loser.
http://www.buckeyejeepers.com/
85jeepn is offline   Reply With Quote
Old 01-08-2008, 12:30 AM   #3 (permalink)
Member # 105975
I've already double checked that, thanks. It's legal here. Anyone have anything constructive to add?
Old 01-08-2008, 03:48 AM   #4 (permalink)
Big91RustyBucket's Avatar
Member # 87635
Send a message via AIM to Big91RustyBucket
Search. And it would help to know what T case you have.
~Philip
Midwestern 4x4 Parts
Originally Posted by FAUX X 4 View Post
You've inspired me to start a build thread of my own.......... all the pictures will be upside down to reflect my driving style!
http://www.midwestern4x4.com
89 S10 Truggy
Big91RustyBucket is offline   Reply With Quote
Old 01-08-2008, 11:00 AM   #5 (permalink)
Member # 105975
NP231D for the t-case.
Guess you didn't see that part in my first post....
Old 01-08-2008, 11:29 AM   #6 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Take a look at this see if it can help you out, hes a Pirate vendor.
http://www.highangledriveline.com/e_brake.html
Also Ive read a little bit about the Caddy calipers and that they arent the best setup but if you did go that route and its enough to get you to pass inspection then you can work on a better setup to your liking with time. What state are you in?
Heres another.
http://www.blackbirdscustomtrucks.com/index7.html
And last heres one kit sold by a vendor here on Pirate..
/forum/axles-tires-wheels/564048-complete-d60-14-bolt-rear-disc-kit-290-shipped.html
Hope that helps.
UCTJ is online now   Reply With Quote
Old 01-08-2008, 11:32 AM   #7 (permalink)
Member # 35586
Send a message via Yahoo to JDKing
i'd just go with the one above /\ how often have you had the inspecter look under yr vehicle. besides yr the po-po make him give you a sticker or bust him for the drugs under the register...
JDKing is offline   Reply With Quote
Old 01-08-2008, 12:13 PM   #8 (permalink)
Member # 9467
Somewhere in late '99 or early 2000 GM put disks on the 14 bolt from the factory. They used drum style hats inside the rotor similar to the ford explorer.
I have a set of caliper brackets from a '99 and for that matter can cut the mounting plate off the axle tube also. The calipers and rotors can be had from any GM dealer. Not a cheap way but it would work. PM if you need more info.
lt1yj is offline   Reply With Quote
Old 01-08-2008, 12:37 PM   #9 (permalink)
Member # 105975
Damn.... was it that obvious?
Old 01-08-2008, 01:07 PM   #10 (permalink)
Member # 81193
I used a kit from Lokar:
http://www.lokar.com/interior_pages/..._concables.htm
I only needed a "connector" between the existing pedal in the cab and the rear axle
phoenixsomd is offline   Reply With Quote
Old 01-09-2008, 12:41 PM   #11 (permalink)
Member # 105975
Anyone familiar with a line lock brake?
5.9L, D60 front, GM 14 bolt rear, Custom suspension, Racing tranny, child seat!
Old 01-09-2008, 05:45 PM   #12 (permalink)
Member # 11921
I like mine. Is it legal? I got a Biondo electric one. Simple install, works great
My build thread: [url]http://www.pirate4x4.com/forum/showthread.php?t=508537[/url]
ramv is offline   Reply With Quote
Old 01-09-2008, 08:23 PM   #13 (permalink)
Member # 105975
Cool, I'll check into it. Sick Ram bro.
Old 01-10-2008, 09:45 AM   #14 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Uhh...he needs a whole system not just the cables.
If you have some fab skilz..make your own. (That's good to know that a driveline e brake is legal in TX...I might do this)
Get a small brake rotor (mini bike or similar) and use a willwood manual "spot" caliper. Not sure if this will work with a 231HD slip yoke though...probably need a flange.
I'm trying to figure out how to fit them inside a my rotors, but I might try a driveline E-brake.
Like this:
Name:  wilwood manual  spot caliper.jpg
MECHANICAL SPOT CALIPER
Features single piston floating housing which permits use in small,
compact applications. Ideal for parking brake. Mechanical
cam-actuated lever with two settings for adjustment. Only 1.6 lbs.
Pads included. 2.95” mount centers. Accepts up to .50” thick rotors
PART # CALIPER PRICE
120-2373 RIGHT $62.94
120-2374 LEFT $62.94
PART # PAD PRICE
150-5982 SPOT $7.29
from http://www.chassisshop.com/
David H. Petraeus for President 2016
guidolyons is online now   Reply With Quote
Old 01-10-2008, 12:37 PM   #15 (permalink)
onetoncv's Avatar
Member # 2160
I don't offer a bolt on kit- But can sell parts- the flange and rotor and caliper if needed- Jess
http://highangledriveline.com
Bringing Innovation to the market !
http://highangledriveline.com/HAD1.gif
530-877-2875
onetoncv is offline   Reply With Quote
Old 01-10-2008, 02:16 PM   #16 (permalink)
Member # 33026
How is everyone hooking these up?? I need ideas for my T Woods set up.
83 CJ9 TBI350/TH350/231/D300 8274 D60/14b, 15" airbags 39" PBMD
94 F350 460 165"wb towpig
Chrisbuilt is offline   Reply With Quote
Old 01-10-2008, 02:59 PM   #17 (permalink)
Member # 25798
I paid my guy an extra 20 and it passed with no probs. Its much cheaper doing that, than getting it fixed. Im on my third inspection with no e - brake and it still isnt close to the rediculous cost of parts GM wants to fix it. This is not a DD that sees alot of road action just fyi....im not THAT guy.
Eisenfaust is offline   Reply With Quote
Old 01-10-2008, 05:38 PM   #18 (permalink)
Etcetera's Avatar
Member # 77599
I've seen similar mechanical calipers like that wilwood that are big enough to fit on a regular rotor. Mount it behind/infront of your hydraulic calipers and you'll have wheel e brakes.
Eric
75 Wagoneer 454/th400/NP205 (looking for the 205, got one in So Cal?)
Etcetera is offline   Reply With Quote
Old 01-10-2008, 07:20 PM   #19 (permalink)
guidolyons's Avatar
Member # 56050
Link?
