PITA 22RE Crank Pulley - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-08-2008, 09:07 PM   #1 (permalink)
Member # 36271
Been trying to remove the crank pulley of a 22RE for a day now. I've been soaking it with PB blaster, had my impact on it, and had a 4 foot cheater on it (overpowering the brakes). Thing still wont budge. I was told it's not reverse thread so correct me if I'm wrong there. Any advice on removing this would be great. How much force can this bolt handle (19mm head) before I'm stuck with a sheared pulley bolt in my block? Thanks.
swiss is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 01:55 AM   #2 (permalink)
johnnytwelvepack's Avatar
Member # 105107
you can try putting your cheater up against the frame and trying to turn the engine over with the starter, that will usually break it loose, but dont hold the key if it doesnt break loose just tap it a few times, if that doesnt work heat up the bolt with a torch and use your impact.
johnnytwelvepack is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 09:31 AM   #3 (permalink)
Member # 83406
i had one of these! we ended up using a 1" impact wrench to get it off and broke 2 adapters in the process. them lil fukers are tight
77 f-150 351w 435205 hd 44 60 42"tsls / 83 toy 4" lift doubler33s detroit frt welded rear 20" bob
weridedirt is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 04:53 PM   #4 (permalink)
Member # 97010
yep been there. my last one was on so tight i had to put 2x4's between the block and the crank and use a 5' piece of pipe. i did not try the heat, but the impact was of no use. once it was out, the who thing was covered in thread locker...good luck
tortis is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 04:59 PM   #5 (permalink)
Member # 79125
Put cheater bar against frame, put it in gear and pull the whole truck with another vehicle.
realmencutfenders is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 07:25 PM   #6 (permalink)
Member # 36271
I've got the whole motor tore down to the block and a PITA crank bolt. So I'm not sure what the repercussions would be in truing to crank it. No electronics left on the motor, so ignition is out, can it be done by jumping the starter directly with a set of cables? Also, how much heat can I out on this thing before I weaken the bolt or do some damage?
Old 01-09-2008, 08:36 PM   #7 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
I had the same problem - motor torn down but still had to get the pulley bolt out. I got a pipe chain wrench - a big $90 sucker made by Rigid. With the engine on my stand, I wrapped the chain around the pulley and held it while another friend backed the bolt out with a long breaker bar. Use a 6pt socket since a 12er will strip the head when doing this.
Lowtorious is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 10:44 PM   #8 (permalink)
Member # 36271
Got 'er done! Wired everything back up to get her cranked over. A bit of heat and with the help of the starter, popped that sucker right off. Thanks for the help!
