rockwell norrowing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2008, 09:42 PM   #1 (permalink)
Member # 83084
rockwell norrowing
does anyone have anygood picks or write ups on the norrowing of the front axle to run the short side shaft on both sides thanks for ur help and info
muddinfool is offline   Reply With Quote
Old 02-12-2008, 11:29 AM   #2 (permalink)
almostthere's Avatar
Member # 45521
here is a good one and another must have link
On page 5 he shows a good way of welding the cut housing. I need to suck it up and narrow mine.
http://www.pirate4x4.com/forum/showt...=419269&page=5
This one is a collection of rockwell threads. There are probably other narrowing links in it.
/forum/general-4x4-discussion/313836-links-rockwell-questions-info.html
Search, you'll find a lot of info. on here.
almostthere is offline   Reply With Quote
Old 02-12-2008, 02:23 PM   #3 (permalink)
Member # 83084
thanks for the help thats what i was after my friends and i are in process of rockwelling a tj and a toyota after that so this will help alot
Old 02-12-2008, 02:30 PM   #4 (permalink)
Member # 75708
There is no short side on a rockwell.
When It Absolutly Positively Must Be Destroyed Overnight. U.S. MARINES
blowntaco is offline   Reply With Quote
Old 02-12-2008, 04:31 PM   #5 (permalink)
Member # 23452
your kidding right, the long side is 7.5'' longer than short side shaft. to the OP check out the buggy that used a stub shaft for a inner, jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote
Old 02-12-2008, 04:34 PM   #6 (permalink)
THIS SPACE FOR RENT
dane's Avatar
Member # 21948
It sounds like you know what you are doing, but I have my hubs flipped on my rockwells under my 4runner and I dont think I would want it to be any narrower. Just a thought, but if you have narrow trails to deal with you might have a different build in mind.
Dane
HOOLIGAN
ROCK
CREW
SEE WHAT THE HYPE IS ALL ABOUT:
http://www.facebook.com/hooliganrockcrew
I WILL TRY BEING NICER IF YOU TRY BEING SMARTER.
FU JS FU KS FU RTF FU FOTR FU DA FU RMK
dane is offline   Reply With Quote
Old 02-12-2008, 07:04 PM   #7 (permalink)
Member # 83084
yea im still learnin on these rockwells there arnt to many people runnin them up here in wash i am puttin a set under my j-3000 on chevy frame with 49's right now it is made to go in the mud pretty much but i will take it where ever i can squeeze it damage isint an issue. I am still undecided on flippin the hubs or norrowing the axle i am building my own wheels so backspacing isnt a biggy either my rig is kinda like the guiny pig we try all the fab work on it
anyhow thanks for all the good info everybit helps.....frank
Old 02-13-2008, 12:30 PM   #8 (permalink)
THIS SPACE FOR RENT
dane's Avatar
Member # 21948
Flip the hubs and your wheel mounting surface is the same as full width 1 ton stuff. Make your own wheels and you are set. Narrowing them is cool, but it seems like a lot of work if its not needed!!
Dane
HOOLIGAN
ROCK
CREW
Old 02-13-2008, 10:52 PM   #9 (permalink)
Member # 83084
yea that sounds like a plan to me ill deffinatly look at that route thanks frank
Old 02-14-2008, 09:31 AM   #10 (permalink)
THIS SPACE FOR RENT
dane's Avatar
Member # 21948
There are threads about flipping the hubs, but if you have any problems pm me and I will walk you thru it!
Dane
HOOLIGAN
ROCK
CREW
