Universal motor mounts for a 350 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-16-2008, 08:02 AM   #1 (permalink)
Member # 3931
Send a message via AIM to Adam F
Can anyone suggest some decent, inexpensive universal type motor mounts for a chevy 350? I am swapping in a 350 in my 88 Toyota and need some sort of motor mount. I'd like to be able to mount it anywhere I want. I'd like to keep the trans in the stock location if at all possible, or move it back in inch or so.
What do you think about these mounts.....
http://store.summitracing.com/partde...5&autoview=sku
Looks like it would be easy to mount, but do you think that one bolt mount deal would be strong enough? My 350 will be a stock type build, no more than 250hp.
I've seen some round bushing style mounts out there. Where can I get a cheap set of those?
Thanks!
http://staff.4x4wire.com/adamf/
Adam F is offline   Reply With Quote
Old 02-16-2008, 11:09 AM   #2 (permalink)
Member # 36385
Get the Advanced adapters YJ 350 swap mounts, Similar design just much stronger
Big4x4Rides is offline   Reply With Quote
Old 02-16-2008, 11:10 AM   #3 (permalink)
Member # 36385
Or just get the toyota 350 swap mounts they sell
Old 02-16-2008, 11:29 AM   #4 (permalink)
Member # 3931
AA mounts are twice as expensive as the trans-dap mounts. They look to be about the same.
Old 02-16-2008, 11:31 AM   #5 (permalink)
Member # 36385
those that you posted are just L shaped, the AA ones have bracing on the side, along with a better bushing. Don't ask for help and then complain about it. Remember you get what you pay for.
Old 02-16-2008, 12:27 PM   #6 (permalink)
Member # 3931
Thanks for the help guys. I found these mounts from http://www.diy4x.com/engine.htm
I bought just the engine brackets, bolts, and bushings as shown for $50, and I'm going to fab up the legs and frame mount using some square tube and plate I have laying around.
Here's the mounts on a tube buggy. Mine will be the same except I will have square tube instead of round from the mount to the frame.
