'88 ford ranger clutch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-31-2008, 06:51 PM   #1 (permalink)
Member # 82042
My friend has a 1988 ford ranger 4x4. He bought a clutch about year ago and this weekend it went out. He doesn't wheel it and is pretty light footed. The flywheel looked good last year. My question is if he should get the flywheel resurfaced? Or what exactly getting the flywheel resurfaced is?
redwreck is offline   Reply With Quote Quick reply to this message
Old 03-31-2008, 07:05 PM   #2 (permalink)
Member # 102365
yes the flywheel will have hard spots in it form heat
resufasing a flywheel is important if u dont do it it will hop around when u take off from a stop
MOLON LABE
urbanmuddboger is offline   Reply With Quote Quick reply to this message
Old 04-01-2008, 10:17 AM   #3 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
i get a new flywheel or get them cut even if the clutch goes 10 miles down the road, also do NOT get a sach(SP?) clutch, i had one and it went after 5k
this was in a 88 b2 2.9L fm146 and stock tires. put in a valeo clutch and havent had an issue uet, i also hear the zoom clutches are good
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 07:39 AM   #4 (permalink)
Member # 82042
Haha thats the clutch he got. I'll pass the word onto him. The clutch went out prematurely because the input shaft on the tranny has about 1/2" of play in it. Lucky him he had just bought a parts pickup.
Old 04-02-2008, 08:43 AM   #5 (permalink)
Member # 87272
Send a message via AIM to rf_blazer Send a message via Skype™ to rf_blazer
I've got the Sachs kit as well, When I got it, the pressure plate seemed beefier then the OEM one... Very not impressed with it right now, if I dont fully depress clutch before getting on the gas, it will slip until I stop accelerating and it's slipping while towing.
Either way, it's an easy vehicle to change a tranny/clutch out on.
(Also, resurface flywheel)
rf_blazer is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 09:11 AM   #6 (permalink)
Member # 50360
i had that issue with that clutch when i first installed it aswell, when i would speed shift (you know flying around showing off) when i hit second it would slip for a good 3 seconds before grabbing fully
Old 04-03-2008, 07:26 PM   #7 (permalink)
Member # 10063
What engine is in it?
If it's a 2.9L, one of the best upgrades you can do is upgrade to the 10" 4.0L clutch. All the parts from a '91-'96 4.0L application fit like as if it were factory.
You'll need to also use the 4.0L manual trans starter (which will require some minor changes to the wiring) and widen the hole in the block-off plate by about 2mm.
The 4.0L clutch has a MUCH better pedal feel to it (not near as grabby, much easier to modulate), and should last nearly forever behind the 2.9 (and of course it has much better holding power too )
Use a Luk brand clutch.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
