to much voltage to lights? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2008, 04:31 AM   #1 (permalink)
Member # 52630
My buddy has a 72 Scout II and when his taillights are on they will get hot enough to melt the bulb and light cover, and the problem gets worse when the truck is running. Has anyone had this problem or know how to fix it?
TrailJP is offline   Reply With Quote
Old 05-30-2008, 06:10 AM   #2 (permalink)
Member # 29177
So what's the voltage reading?
Check the clearance between the taillight lens and the housing. Maybe they are too close to each other.
Blind Driver is offline   Reply With Quote
Old 05-30-2008, 06:20 AM   #3 (permalink)
Mechanos's Avatar
Member # 6704
Is he using those extra bright halogen bulbs? They produce more heat than a standard bulb.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 05-30-2008, 07:10 AM   #4 (permalink)
Member # 52630
He is using regular bulbs #1157 in rear, and he has not checked the voltage to them, but if it is to high what does he need to do to fix the problem? Also, what could cause the voltage to be high? What should the voltage be 12 volts?
Old 05-30-2008, 08:53 AM   #5 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Old Scout is offline   Reply With Quote
Old 05-30-2008, 08:56 AM   #6 (permalink)
AF6 OD
R290's Avatar
Member # 46467
Measure the battery, should be 12-14 volts, most Scout would be lucky to even get 11 volts at the tails lights. I would suspect the housing has a short to ground some how. (P.O. mods, trailer wiring,etc) Turn it on and feel where the heat is starting to come from and look close. The glass bulb gets hot, but the base should not get that hot.
73 IH Scout
R290 is offline   Reply With Quote
Old 05-30-2008, 09:40 AM   #7 (permalink)
Member # 97584
Resistance causes heat, not necessarily over-voltage (unless you're shooting well above 12v). I'd check the ground, check the wiring for breaks or kinks or corrosion, check the socket for the same thing.
You should be getting anywhere from 11-14v would be in the "ok" range. If you're getting more than that, your alternator and/or voltage regulator have problems. I would bet almost anything that you're shorting to ground somewhere near the socket, though.
Crawdad is offline   Reply With Quote
Old 05-30-2008, 10:38 AM   #8 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
This is most likely your problem.
Im an ASE Master Tech and 90 percent of elecrtical problems I repair are caused by increased resistance. Poor connections, etc.
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 05-30-2008, 05:56 PM   #9 (permalink)
Member # 81644
While the high resistance/too close lens ideas are likely spot on, if all the lights seem freakishly bright, then I'd not overlook the idea that the voltage reg is bad. Check voltage at the batt with motor running. Technically, if you are seeing > 14.5v or so (in actuality, it would likely be >16v with a bad VR) then you should replace the voltage reg, or the whole alt if it's of the internal/integrated type.
90 Toy Land Cruiser, 05 Suzuki Z400, 04 Yamaha Warrior, 03 Cannondale Speed 440.
WileECoyote is offline   Reply With Quote
Old 06-02-2008, 08:20 AM   #10 (permalink)
NVScouter's Avatar
Member # 18152
If you want to know how much voltage/amps you should be getting to ANY component you need to know WTF that component is rated for. Really its that simple.
You have the part number so what does it say? Now what are you getting? does it match?
If anyone wants to know why illegals should be kicked the hell out, ask someone that busted their ass to be here legally!
NVScouter is offline   Reply With Quote
Old 06-02-2008, 10:18 AM   #11 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
the 1157's will take up to 14.7volt, thats what i have at the rear of my b2 and they never blow, so you shoudl check what everyone else says
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
