dana 60 look up help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2008, 09:16 AM   #1 (permalink)
Member # 82152
so i look around the site and found a few thing that help me but not forsure.
I bought a blazer off the guy. he said it had a 14bolt and a dana 60 front. well being new to all this(2ed bulid) iam un sure if it has a ddana 60
any input any one
on the case dirver side it says k gm 4
other side number read 14030376.
and over on both side of the axel rigtht under the crown nut isit says 620215
is it a dana 60
i also look for the stamp for the 44 and the 60 no luck
it has 10 bolts around but is not a circle..
thnaks forthe help
fra66le25 is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 09:29 AM   #2 (permalink)
trkklr77's Avatar
Member # 29016
there is always the 60 bible in the tech section.
does it have ball joints?
does it have 3 or 4 ubolts?
how big is the locking hubs?
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 09:53 AM   #3 (permalink)
meangreen39's Avatar
Member # 112940
compare your lockouts to a known halfton lockout, if yours dwarfs them that will get you closer, then compare the front cover it should be alot bigger.
meangreen39 is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 04:45 PM   #4 (permalink)
Member # 92402
If it is a 60 then it should have 9/16 bolt heads. A 44 should have 1/2 bolt heads.
Chris
Tellico online rally post #690.
04'Rubi,tons,leafs,38's/99'TJ,stock
Jeep74j20 is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 05:03 PM   #5 (permalink)
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
I bought a blazer off the guy. What year blazer? he said it had a 14bolt and a dana 60 front. Did he say he swapped it in or it's stock? well being new to all this(2ed bulid) iam un sure if it has a ddana 60
any input any one
You mean castle nut? Like this?
is it a dana 60
thnaks forthe help
How about a picture or two?
Urban Wheeler is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 08:38 PM   #6 (permalink)
Member # 82152
casetle nut .. yea that is what i was trying to point out... I talk to a few rear end shop and one of the owners said it was a gm 8.5inch witch is like the dana 44 and it if i pull the ring out and it was 9inch it would be a dana 60(the ring gear) ill look again. also i did not see a king pin and or a king pin spring.. i also called a few gm dealer parts department and they dont have the old style part book i guess you could say so now they are no help i will try to put pic up later to help. i think some one got the best of me and need an ass woopin.. what a grate start to a new build
Old 06-03-2008, 02:10 AM   #7 (permalink)
Banned
Member # 111451
The 10-bolt GM front and the D44 front are similar in strength. But the diff. cover looks completely different between the two. The D60 has the same shape of diff cover as the D44 but is larger.
http://www.pirate4x4.com/tech/billavista/60_front/
Scroll down about 1/2 way to see a D60 diff cover for comparison.
a360chief is offline   Reply With Quote Quick reply to this message
Old 06-03-2008, 04:44 AM   #8 (permalink)
Member # 48799
I'm guessing the front is a Corp 10. The number 14030376 looks to be an AAM (American Axle & Manufacturing) carrier casting number. It's possible the rear is a 14-bolt (Corp 14) also built by AAM.
BTC_CJ7 is offline   Reply With Quote Quick reply to this message
Old 06-03-2008, 07:08 AM   #9 (permalink)
Member # 112940
i think a can of whoop ass is in order.
Old 06-04-2008, 07:26 PM   #10 (permalink)
Member # 82152
yea a ass woopin .... welll after looking more and more and looking over the numbers is is to be a d44 so .. owell... lucking for me a co-worker was willing to buy the truc from me for 1500 what i paid for it ... i did have to eat the dmv the were of course not paid... that was 2hr in line and a 240 pay out... but like i said he is will to by it from me for 1500 this sat so now i am looking for another true dana 60... let this be a lesson to all the new be ...
thanks for all the input guys
the guys name is josh and his number is 408-476-2937 if any one feel like getting the asswhole input... in the middle of the night
