What transfercase should I use behind a TH350 in a Jeep YJ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2008, 11:03 AM   #1 (permalink)
Banned
Member # 42730
Currently running a small block chevy with NV4500 and 231 case, thinking of swapping to a TH350, what transfer case is easiest (read CHEAPEST and BEST) to use?
chewingum is offline   Reply With Quote
Old 07-21-2008, 11:35 AM   #2 (permalink)
kf4zht's Avatar
Member # 80248
Easiest, cheapest and probably the strongest would be the NP205. You can get them stock behind a TH350, gear driven, usually only 100-200 bucks, twin stickable with both kits and DIY. Only minuses may be extra weight, only a 2:1 low, may be longer and you may need a clocking ring (but they are cheap).
You can fix the 2:1 low with either new gears or a doubler in the future.
Where there is a way, there's a will.
[size=4] [font=arial black] [url=http://www.tricktools.com][color=Yellow] Check out Trick-Tools.com for all of your metal fabrication needs! [/url][/color][/font] [/size]
kf4zht is offline   Reply With Quote
Old 07-21-2008, 04:23 PM   #3 (permalink)
Member # 94186
an atlas
1988 4.3cpi v6 sased 37mtrs and one proud owner
bigarms23 is offline   Reply With Quote
