| View Poll Results: Winch mount | |||
| Multi mount |
1 | 4.76% |
| Front mount |
17 | 80.95% |
| NO winch only bacon |
3 | 14.29% |
| Voters: 21. You may not vote on this poll | |||
Member # 102167
Winch mount
I need to make a decision on how to mount my winch. I was set on doing a multi mount but now I'm debating on that or just mounting to the front. The advantage I see to the multi is you can use it front or rear plus take it off when not wheeling so it woun't be stollen. The dis-advantage is extra wiring cost. The front mount would be cheaper and maybe stronger but it will sit in the weather and be easier to steel. What do you think?
TheTonka;"Mostly cause I'm an asshole, with little hope of reform." |
#2 (permalink) | |
POOPSMITH
Member # 88383
if you go with the bumper mount and want to be parnoid, on my car trailer i ended up tacking a few of the bolts kinda thick so you cant get a socket on it, but it will only take a minute or so of grinding to get it off if needed |
#3 (permalink) | |
Member # 38118
I was going to go with the multi mount on mine. Then I figured I would end up on a situation where I needed my winch and it would be sitting at home. A friend of mine had his on a multi-mount and ended up never taking it off, so he finally just permanently mounted it.
Member # 15668
Front mount with recommended tack welds. If they want the winch that bad they will just steal the rig. 125' of cable some tow straps, tree saver or so and a couple of pillow blocks and D rings and you can reach just about anything. Just my $.02 on the subject.
Always been interested in one of these:
http://www.misch4x4.com/winch_lock.html Two of your bolts run through it into the winch, then the cover goes on and locks in place. No grinding to pull the winch. One bolt version http://www.tuffyproducts.com/p-161-1...her-bolts.aspx Justin Last edited by Hoxviii; 08-05-2008 at 08:20 PM. |
playinwithit
Member # 97574
Tack weld washers to the bolt heads, then beat the washer down around the bolt head so you can't get a wrench on it. Just some simple grinding and prying to get them off when you want.
Playin' with my Willys buggy build |
Member # 102167
I'm suprised knowbody has voted for the multi mount. It seems like a cool idea. You can use it in the front or rear and with the proper set up you could put it on anyones rig tha has a reciever. Or even on a trailer. Maybe people are seeing something I'm not? I would love to here some reason why front is better than multi. P.S. bacon speaks for it's self.
playinwithit
Member # 97574
Cause the object is to go forward, not backward!
![]() My buddy has receiver mounts on his YJ, I couldn't stand the winch sticking out like that catching on everything and robbing attack and departure angles.
Member # 47848
Mutli mounts do offer more options for getting un stuck but the extra wiring could be cost prohibitive. I've never liked the look of multi mounted winches. They also hurt your approach and departure angle. You could mount it inside but then you've got to make space. When you need it, you're likely to have to unbury it from the rig.
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne [/QUOTE] 1999 4Runner |
