Quick driveshaft questions
I need to start compiling some cores for my driveshafts. I'm looking for an application with a 1310 double carden joint that bolts to a u-joint yoke, not the flange output. What rigs should I be looking under?
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE] [QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit. [/QUOTE] |
Member # 87704
I found one under the front of an 86 J-10 that I had, pretty sure it was 1310 but coulda been 1330, its been a little while back. But wouldnt hurt to check it.
"That BASTARD Retired the Day he was BORN!!!" |
I had heard rumor that FSJ's were a source, but I was looking for someone to back that up. Thanks. IIRC there was a Cherokee/Wagoneer at the boneyard last time I went there. I'm not even sure what it had for a drivetrain. I know my buddy was hoping it had a 401 (it had a 360) since he's an AMC fiend and that the t-case shifter was on the floor/side of the trans tunnel. I'll have to go investigate it more closely...
Member # 47848
What about the ealry to mid 90's Dodge 2500 with extended cab?
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne [/QUOTE] 1999 4Runner |
#6 (permalink) | |
Member # 87704
I actually scored a core tonight, but now I'm not so sure I want to go that route. I knew the travel was limited on the CV's, but FAWK...worn out stock 1976 Blazer front suspension darn near maxed this thing out. Now I'm back to thinking I'll just run a u-joint front shaft and deal with the vibes. Unless someone wants to donate a doubler adapter to the cause...
My old Toyota stuff was so much easier to deal with. If all else fails I can just run the Toyota to 1310 adapter u-joints, but they're $50 a piece and not exactly a stocking item at parts stores. I was hoping to use the 1310 stuff because you can damn near get a Precision 369 joint at a gas station to get you back on the road. So...input on what I should be doing? 355/TH350/205 with 1310 yokes on both ends in a 1993 Toyota running Toyota axles and the "big" flange pattern...
