Removing welds??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2008, 03:27 PM   #1 (permalink)
Member # 115241
Send a message via AIM to varsis
Removing welds???
I know I can remove welds using a Ace/ox torch but can I do this using a regular torch? Also how hot can I get the axle without wrecking it? (Fully Assembled.)
1997 Dakota, 4x4 green almost on 38's with 5.38 gears! and shift kit, with 5.9L mag. 64" deavers rear.
[URL="http://4wheelin.ca"]http://4wheelin.ca[/URL]
varsis is offline   Reply With Quote
Old 08-20-2008, 06:23 PM   #2 (permalink)
Member # 105299
Send a message via MSN to big giant head
Regular torch what do you mean? And it depends on how much you are removing, perches are no problem unless its like a samurai with 1/8 inch axle tubes
Owning a handgun doesn't make you armed any more than owning a guitar makes you a musician.
big giant head is offline   Reply With Quote
Old 08-20-2008, 06:33 PM   #3 (permalink)
Member # 17904
no, you can't do it without the oxygen. You'll most likely melt the seals or at least burn the gear oil into something solid.use a cutoff wheel or sawzall if you can't get an oxy/acet torch
HalfFastFord is offline   Reply With Quote
Old 08-20-2008, 07:31 PM   #4 (permalink)
Newbie
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
what is Ace fuel? I have removed perches and brackets with a torch that was running acetylene. i have also used mapp too and both worked fine. I didnt melt through anything i wasn't aiming for. You just gotta be good with the torch .
92 Nissan Pathfinder- Front 3 link, EB d44 with full chromos and OX, rear 4 link h233b with full detroit.
02 Dodge 2500 QC LB 4x4, CTD, nv241dhd, 500 hp daily.
89 Dodge D250 CTD - New Project Truck
72 Datsun 240z Race Car.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote
Old 08-21-2008, 11:16 AM   #5 (permalink)
Member # 47848
I'd suggest a cut off wheel, grinder or Sawzall. With heat you have the potiental to wreck seal, blow a hole in the axle tube or warp something.
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne
[/QUOTE]
1999 4Runner
4x4mike is offline   Reply With Quote
Old 08-21-2008, 02:04 PM   #6 (permalink)
weck's Avatar
Member # 46645
Originally Posted by yozsi View Post
what is Ace fuel?
Believe they were referring to acetylene...
X2 on the cut off wheel or grinder.
weck is offline   Reply With Quote
Old 08-21-2008, 03:04 PM   #7 (permalink)
Member # 14637
Gouging rods in an arc welder can be very effective and quick as well.
"Roof - doors - wheels, it's the way I drive !"
Mudplugga is offline   Reply With Quote
Old 08-22-2008, 10:21 AM   #8 (permalink)
Member # 65863
X2 on the cut off wheel or grinder.[/QUOTE]
along with a BFH.
85gmac is offline   Reply With Quote
Old 08-22-2008, 02:54 PM   #9 (permalink)
Member # 107569
Use a torch with the smallest tip on it.
If I remember right there are five excuses for drinking: the visit of a guest, present thirst, future thirst, the goodness of the wine, and any other excuse you choose! :smokin:
aaron92685 is offline   Reply With Quote
Old 08-23-2008, 07:34 AM   #10 (permalink)
Member # 33456
go to home depot and get a tube of weld remover.
massxj is offline   Reply With Quote
Old 08-23-2008, 08:19 PM   #11 (permalink)
Member # 53056
arc gouge hope you dont mind sparks..
1979 FJ40, 60s, 42s
87 toy pickup under the knife
jimbo85yoat is offline   Reply With Quote
