visual difference of a 2 bolt and 4 bolt main engine? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-27-2008, 07:42 PM   #1 (permalink)
Member # 118843
does any one know how to tell the difference between a 2 bolt main or a 4 bolt main block?of a 350? for 83's and down
johncj is offline   Reply With Quote Quick reply to this message
Old 08-27-2008, 09:33 PM   #2 (permalink)
Member # 106663
Location: South Park . . . . . . . . . . . . . . . . . . . ,,_ . . . . . . . . ,-'`-, . . . . . . . . . . . . . . . . . . . .\,, '``-.__.,.,./ .,., .\ . . . . . . . . . . . . . . . . . . . . .|,.-;`;` . . ,.,., .,.,.,`-, . . . . . . . . . . . ..,,,.,.,._ . .
Take the oil pan off. The main bearing caps will either have 2 or 4 bolts each.
Durrhh.
Filthy McChevy is online now   Reply With Quote Quick reply to this message
Old 08-28-2008, 05:05 AM   #3 (permalink)
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
If you can't do that then you have to get the casting numbers and look it up.
Urban Wheeler is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 12:50 PM   #4 (permalink)
Member # 105338
http://www.mortec.com/castnum.htm
Pretty decent listing.
Unka-Boo is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 03:23 PM   #5 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
rumor has it that if you have the large 8"(or so) balancer, then its a 4 bolt main, and the smaller is a 2 bolt main. They are swappable, so that really doesnt mean nothing. The same casting number on some blocks is used on a 2 and 4 bolt main applications. If you are shopping for a 4 bolt main, and dont plan on making huge power, I personally think you are wasting your money. Buy a 2 bolt main, argrue its not a 4 bolt, and therefore not worth as much to you, use that as leverage to get the motor cheaper. Build it, enjoy it.
masterbeavis is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 10:29 PM   #6 (permalink)
Member # 118620
Originally Posted by filthy Mcchevy View Post
take The Oil Pan Off. The Main Bearing Caps Will Either Have 2 Or 4 Bolts Each.
X2
ErichB is offline   Reply With Quote Quick reply to this message
Old 08-29-2008, 05:06 AM   #7 (permalink)
Member # 26369
That is a good point. A 2 bolt block will still hold a lot of power. If you can't find one and really want one, talk to an engine shop about converting a 2 bolt to a 4 bolt.
Old 08-29-2008, 05:29 PM   #8 (permalink)
Member # 32298
you can also tell by the casting 'for most, not all' at the front by the timing cover, if its thick, its a 4 bolt, if its thinner, its a 2 bolt. kinda hard to explain instead of showing, ill see if i can find a picture
onebad4x4 is offline   Reply With Quote Quick reply to this message
